Originally Posted by krisr
If you’re using the factory plastic intake and fuel rails you could make brackets off the rail mount bolt holes and set the shaker scoop up that way so it’s there for looks or run an Injected 4bbl intake with an accufab throttle body. If the engine mounts put the motor in the right spot too.
There are also plenty of adapters to run stock 3 bolt and 4 bolt LS throttle bodies vertically on a single plane manifold - you really do need a fair bit of cam to make those 4bbl style manifolds work, however
