When, if ever, does the left signal indicator LIGHT ... not flash, but does it ever light up?
Usually if it lights up and stays steady with the turn signal ON .. it's a problem with the exterior bulbs.
If it NEVER lights up it's usually a burnt out bulb, OR if you are using LEDs the bulb is installed 180 degrees out (wrong polarity). Could also be a bad printed circuit, dirty contacts on the bulb carrier etc.
