Timely discussion, I'm considering discarding my old Comp Engineering subframe connectors with the Chassisworks G-connector system.
While pulling out my rear a few weeks ago, I had cause to drop the sub-frame connectors and noted quite a little bit of distortion in the forward bolt holes the original body mounts. I have solid aluminum mounts...just need to find the time to install them. The subframe connectors will get welded in this time go round.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
