View Single Post
Old 07-15-2022, 12:01 PM
John Milner's Avatar
John Milner John Milner is online now
I have had good luck with a cam like a Summit 2802 (224 234 .465 .488 114) in 400's up around 9.5-10:1 compression and 3:55 gears. It will idle with a slight loap but still have plenty of low end torque. A lunati 703 would work well also. I ran that camshaft in a 10:1 428 and it ran strong with a slight loap. Both of those camshafts will like the 2500 stall/3:55 combination. An 041 will sound great and run decent but will have less low end power than both the 2802 summit and 703 lunati cams. It really could use 10:1 compression minimum and a lower gear than what you currently have.
The Following User Says Thank You to John Milner For This Useful Post:
