Old 05-23-2024, 03:52 AM
gman005's Avatar
gman005 gman005 is offline
Mine are not DOT approved.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 05-23-2024, 10:50 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Originally Posted by yellow1098 View Post
For that radial tire slick….can I put them on before and drive to the track? Or can they not be driven on the street at all?
Slicks are not legal or recommended for street driving and some of my bud's say drag radials aren't much better if you get caught in the rain. Put them on at the track!
Chris D
Old 05-23-2024, 02:44 PM
Dragncar Dragncar is offline
No, but with Micky Thompson ET Street Radials you can.
Hoosier makes one thats says DOT but you can not actually drive it on the street. Made for class racing.
Old 05-23-2024, 04:01 PM
yellow1098's Avatar
yellow1098 yellow1098 is offline
I currently am running the ET street R’s on my snowflake 17’s on the street….when I go to my 15’s with the radial slicks for the track I was wondering if I could put them on at the house and drive out to the track or I would have to load them up and put them on at the track …or need to bring a jack and all the tools and all that
Legal?? Meh hahaha
Old 05-23-2024, 07:15 PM
RJRjr's Avatar
RJRjr RJRjr is offline
I drive to the track on my m/t 275 radial pro's. Im only 4 miles away though. They work great by the way. Best 60' of 1.49. Used to have m/t 10.5x 28 stiff sidewall slicks. The radials liked a way tighter front shock setting than the slicks. Took a while to figure them out, but glad I did. Stable down track. Slightly faster et.
The Following User Says Thank You to RJRjr For This Useful Post:
Old 05-23-2024, 07:56 PM
RocktimusPryme's Avatar
I drive my ET Street S/Ss on the street. I do not like driving the car in the rain under any circumstances because the wipers are trash, but Ive been caught in the rain and its not really any worse than 550+ HP on your average Cooper Cobra or other white letter 15" tire.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 05-27-2024, 12:07 AM
yellow1098's Avatar
Ok next question to follow up…..what size tires are you guys running on the front? Are you running skinnies?
Old 05-27-2024, 10:33 AM
Skinnies up front can pick up time-even more than the weight reduction due to less rolling resistance. I did it at the track back to back.
Old 05-27-2024, 11:09 AM
yellow1098's Avatar
Exactly why i would like to run them…..but Im not sure what size skinnies I need for my TA on 15’s with my 28 inch tall slicks ill be running on the back…..these are the rims ill be using
