70 ssj query...
i just picked up a 70 ssj. It is in pretty ruff shape. Someone had taken the body off the frame over 10 years ago, then quit the project. It has set outside with the parts piled inside the car since.
My question...the sunroof has been taken apart and i do not see the electric motor that operated it. The other stuff seems to be there tho. Would a electric motor from another application work on this? I believe i read that some caddy stuff may be the same? |
It was an ASC roof used in the 70, used int mustangs and cougars as well as Caddy.
Try http://www.cougarpartscatalog.com/sunroofparts.html (Thanks to Harvey... I'm sure he will check in to htis thread shortly) KV |
Heres the sunroof motor mounted in my 71 for reference. Last piece of the puzzle I have left to remove! Don't know if its exactly like the 70. Best of luck on the build!! Pics are a must!! Dave K.
ok, thanks, i will get a couple of shots and post in the next few days.
Wow a '70 SSJ, that's my dream car. Hopefully it's black.
sorry it is a white one, but came with the 455 and 12 bolt!
I believe the 70's had the motor in front of the roof opening at the center (basically above the rear view mirror). The 71's & 72's had a completely different unit (Bosch, German, Mercedes) and the motor/gearbox is mounted above the left rear passenger area. The 70 will also have a little cap in that front area that you can pop out to insert a manual crank tool.
In mrrat's (Dave) picture you can see how Hurst did a hack job to get that roof assembly into the GP roofline. Mine looks like mrrat's and is loaded with sharp unfinished edges & bent brackets & plates that look like they were made on someone's workbench. Your 70 used a Cadillac sunroof assembly, but I don't think they were actually made by GM back then. Webasto & ASC had a hand in those units. The name Golde also comes to mind, but I'm sketchy on those units. I will tell you that the history & detail of those sunroofs is sketchy, but here's a cool website to learn more:http://www.coachbuilt.com/bui/a/asc/asc.htm Did your 70 SSJ belong to a guy named Jeff in Georgia at one time? Or did it belong to a guy named Van? Have any pictures you can post?
1970 SSJ: 272 1971 SSJ: 157 1972 SSJ: somewhere between 60 and 350... |
Oh those pics hurt
I had a 77' GP with a factory option steel sunroof.
There was a plug for the manual crank lever in front of the sunroof and behind the switch, and the lever was included with the car. Fortunately the sunroof never failed or leaked - we owned the car from 86' to early 92'. Perhaps parts from 73-77 A & G body cars can work. |
motor/ switch
Working on car and bringing this btt:...would this be the correct motor for the sunroof on this car? Trying to locate one and also the correct switch. thanks in advance.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
JC...hard to know for sure. I've only come across a small group of 70's and I've never had a chance to see one in the roof exposed.
I do see the hand crank gear there, so it's a strong possibility. Only the 70's had this version. That should be a Bosch (german) unit, so see if you can cross-reference the part number I see on it. It should correspond to the 69-70 time frame. And just for reference, the motors (and just about everything else) was different for the 71's and 72's, including the hole size in the roof, so it can be a bit confusing. I can't find any factory manuals that show exploded views, R&R, or parts lists.
SSJ Sunroof
I have no idea why that double-posted...
I believe I still have two switches nos in the box that came with my 70 ssj I bought years ago.
sent pm.
ok!, seems I have found a supplier for the motor and associated hardware needed to get this part of project done. I will post pics as soon as the pieces are in hand.
Just an additional note on mrrat's picture: that red tube to the right side of the photo is the housing the drive cable traveled back and forth in . So when the roof was closed the cable was mostly out of the red tube and running dead center behind the roof panel. As the roof opened, the drive cable went through this tube and ended up wrapping around going forward just below the driver's side roof drip molding (inside the roof of course).
Who did you find as a supplier, JC?
As soon as I get the parts and determine them legit, will post the info.
