2004-06 GTO Parts FOR SALE/WANTED PARTS for sale/wanted |
![Reply](images/cars/buttons/reply.gif) |
![Old](images/cars/statusicon/post_old.gif)
12-18-2012, 01:20 PM
LS6 Intake manifold
Looking for LS6 Intake manifold to replace the stock ls1 on 04 GTO
Aftermarket considered.
Thanks..
12-19-2012, 12:34 AM
![Rocky Rotella's Avatar](image.php?s=32324bf54e8f55d9441a284a2bf3ca74&u=145902&dateline=1627222499) |
The two manifolds should be the same. The LS1 used the LS6 manifold beginning in 2001.
12-19-2012, 01:12 AM
LS6 Intake
Rocky,
Thanks for the input. However, I was under the impression that the Corvette had a different manifold than the GTO, in 2004. That manifold was the LS6 as compared to the LS1 manifold on the GTO.
Am I wrong?
Mike Wasson
12-19-2012, 09:36 AM
all the F bodys Ive had that were 01,02 had them.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
12-19-2012, 10:03 AM
The 2004 GTO had a cable actuated throttle body while the Vette had a electronically controlled TB. Otherwise, it's the same, so you should be good to go from a performance standpoint.
12-19-2012, 10:23 AM
![MoonShiner's Avatar](image.php?s=32324bf54e8f55d9441a284a2bf3ca74&u=153762&dateline=1173841079) |
LS6 intake is basically the same as the LS2. It's an upgrade for the LS1. You'll probably have better luck on the ls1tech forums.
12-19-2012, 10:32 AM
If you're speaking strictly in performance upgrades, then the LS2 and LS6 manifolds may be similar, but the LS2 manifold has a larger diameter TB and is shaped a bit differently.
12-19-2012, 10:35 AM
Yes Rocky, I was speaking of performance. Thanks.
Here is an article comparing the LS1 and LS6 intakes and an aftermarket one.
http://www.highperformancepontiac.co...r_102_intakes/
12-19-2012, 10:42 AM
Thanks. I thought that's what you meant but wanted to clarify.
12-19-2012, 10:45 AM
And OP, Rocky is correct your '04 GTO already has what is essentially an LS6 intake. I always forget that being an LS2 guy....
