Old 03-10-2022, 08:56 PM
62olds 62olds is offline
Default Engine mounts to block bolt size and thread pitch.
Hello I have a question about Engine mount bolts. I am purchasing an engine. I also have purchased a Motofeet engine stand which mounts to the block using two of the five holes in the block to attach. I need to bring bolts that are about one inch longer than the origin mounting bolts when I pick up the motor. Can someone please tell me the size, thread pitch and length of the original factory bolts. Thanks. [ ATTACH]585868[/ATTACH]
Old 03-10-2022, 09:08 PM
Sirrotica's Avatar
7/16 shank, X14 thread pitch. I believe the OEM bolts are 3/4 inch long.
The length is from memory, as I don't have any OEM bolts handy.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-10-2022, 09:18 PM
Thanks, my engine is still in the car therefore I don’t have easy access to my bolts.
Old 03-11-2022, 08:01 AM
25stevem's Avatar
25stevem 25stevem is offline
Figure on the bolt holes in the block being 1/2” deep, then you need to add to that the thickness of that engine stand the bolts will pass thru.
Once you have that number I would add 1/4” of length to the bolts you buy and then also buy a fist full of 7/16” washers in case you need them, especially if you can only get bolts that are overly long for what you think you need!
I do stuff for reasons.
Old 03-11-2022, 03:13 PM
Kenth's Avatar
Kenth Kenth is offline
Original sizes for bolt and washer is:
Bolt Insulator to Cyl. Block 7/16"-14 x 1"
Washer Insulator to Cyl. Block 7/16" I.D. x 13/16 O.D. x 1/8"
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-11-2022, 06:12 PM
Thanks for your reply
Old 03-11-2022, 06:13 PM
Thank you for the information
