I'm not even sure this is feasible hence the question, but has anyone ever machined down a 3 series ring gear to fit a 4 series spool? I'm currently running the "thin" Yukon 3.90 gears in my bracket car with a full spool running 275-60-15 drag radials. I generally race the street/foot brake class hence the radials over slicks. My problem is my very stout TH400 transmission has a 2.75 first gear so overpowering any tire isn't too difficult. I know I can go to the thin 4 series 3.73 but I'd like to get into the 3.42 to 3.55 range and sadly no one seems to make a 12 series ring in those ratios for a 4 series carrier.
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Is a 3 series spool not available for your application?
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U ![]() |
Believe it or not, nobody makes a 3 series full spool for a 12 bolt.
Strange has them in 33 and 35 spline. I didn't see one for 30 spline.
You're right, I forgot to mention that I have aftermarket 30 spline axles and C clip eliminators so I'd rather not replace those again. My best bet is to probably go with a Eaton posi and be done with it.
3.73 is it for a 4 series spool.
That is what is so attractive about a ford 9, spool in any ratio. Even a Dana is limited to 3.54. |
Your gear could be machined, a real machinist would need to perform the job, though.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
not so sure of that - those gears are hard as hell.
I have a thin 3.73 in the IA/Camaro's 12 bolt Moser spool 33 spline.
Most machinist's would not tackle this job. I have been blessed to have a friend that's a real deal machinist. He likely would do such a job for me, not many others...just because of the degree of difficulty...
Not that hard where it needs to be cut. No problem with carbide mills.
Having said that; I can't speak about the overall gear design, regarding the resulting strength of the gear. Also, if the result is too little bolt thread engagement in the gear, that's a problem. I imagine that the gear is too hard to drive a bottoming tap another 1/4" or so into the gear.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
My 2-Series and 3-series 12-bolt posi chunks sold like hot cakes awhile ago. Got no more, just good used guts.
Got a ring gear spacer of a correct thickness for some sort of series/gear swap. Probably have the longer bolts.. |
Such a hard-steel gear would be grinded. right?
Probably at equal cost of a custom spool from Strange. |
I had the cover off my 12-bolt the other day and didn't remember how thin the 3.73 (11/41) for a 4 series carrier looks. I'm not sure if a 3.42 (12/42) or 3.55 (11/39) was machined for a 4 series carrier that there would be enough material to support the ring gear teeth. It wold be interesting to see what the difference is in the pinion size of the three gear sets.
.310" is the difference between a 3 series and 4 series carrier.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U ![]() Last edited by firechickenman; 08-11-2016 at 10:43 PM. |
