Old 03-29-2024, 09:35 AM
napster's Avatar
napster napster is offline
Default Novice question about intake manifold
What is the item to the left of the thermostat housing and what does it do?
Thanks.
ID:	631291   Click image for larger version
Old 03-29-2024, 09:59 AM
It’s a thermal switch that controls the vacuum advance in relation to what gear the transmission is in.
Old 03-29-2024, 10:08 AM
napster's Avatar
Does it matter if the transmission is auto vs manual?
Old 03-29-2024, 10:15 AM
I forget, I am not home to consult my manual.
Most folks do not even have the needed vacuum solenoids any more that the switch controls, that much I can tell you.
Also this set up was only for emissions purposes.
Old 03-29-2024, 11:02 AM
jhein's Avatar
jhein jhein is offline
Yes, it's for the TCS system. It controls the vacuum advance based on water temp and also what gear your in and I thought it was used in both auto and manual cars. I have mine in place just for appearance but it's not functional, I don't have all the other components and personally, I think the motor runs better on manifold vacuum. Like Steve said, it was done purely for emission control.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 03-29-2024, 03:08 PM
jhein's Avatar
Here's a better explanation of how it works from @Joe's Garage:
If the system is functional it energizes the solenoid that allows full manifold vacuum to the vacuum advance when the engine is very cold - helping with the choke system and idle during warmup.
It also energizes the solenoid if the engine gets too hot either at idle or low speeds - applying full vacuum advance and increasing the idle speed to help with cooling the engine back down.
In addition to this coolant temp sender activating the solenoid, it is activated by either a speedometer cable switch (on automatic transmissions) or a switch on the 3-4 shift lever (on Muncie transmissions) to allow full vacuum advance only in high gear on automatics or 3-4 gear on manuals.
The Following 2 Users Say Thank You to jhein For This Useful Post:
Old 03-29-2024, 03:45 PM
VCho455's Avatar
VCho455 VCho455 is offline
If I'm not mistaken it also ports vacuum to the flapper(s) on the factory air cleaner.
Old 03-29-2024, 05:45 PM
Kenth's Avatar
Kenth Kenth is offline
Vacuum to the "flappers" on the factory air cleaner is taken from the #1 runner on the intake. It has NOTHING to do with the TCS system.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 03-29-2024, 06:13 PM
And is the most common vacuum hose left off by mistake as sometimes even pivoting the air cleaner base around to drop its locating tab in the carb will pull it off.
