Old 10-14-2021, 08:56 AM
dataway's Avatar
dataway dataway is offline
Default Dipstick tube question
I've got a 69 compressor mount on my 68 GTO because I like the easier access to the spark plug ... anyone know if I can (or should) use a 69 upper dipstick tube instead of the 68 I have on it now?
Reason I ask is I found an NOS upper tube for 69 AC V8s and I thought it might fit better since I'm using a 69 AC mount.
I do however have a re-pop lower tube installed ... not sure if that messy up this plan.
Old 10-14-2021, 12:37 PM
I have the stock upper dipstick assy from a 72 AC system. I think the length is all the same but there might be a difference in the screw mount tab due to Aluminum AC bracket vs stamped steel.
Old 10-14-2021, 06:44 PM
dataway's Avatar
Yep the mounting hole is what I was wondering about, I am using the large 68 Aluminum front AC mount, and the 69 lower pivot mount.
