Old 03-21-2024, 07:55 AM
Tim Corcoran's Avatar
Default Zero or -.005
I always thought a true .000 deck height with a .040 head gasket was good practice for an efficient engine. My machinist recommends -.005 says zero with a .040 gasket is too close. I am using 6.8 Eagle rods and a 4.25 Scat forged crank and E-heads. I mocked it up yesterday with pistons in four corners and it's currently -.012, -.014, -014, -.015. What is your experience. Thanks.
Tim Corcoran
Old 03-21-2024, 08:19 AM
PAUL K's Avatar
PAUL K PAUL K is offline
We shoot for zero to .005 above the deck for a factory block build. Never had an issue.
Go fast, see Elvis!
The Following 5 Users Say Thank You to PAUL K For This Useful Post:
Old 03-21-2024, 10:21 AM
With a .040 head gasket?
Tim Corcoran
Old 03-21-2024, 11:46 AM
PAUL K's Avatar
Yes.....even an .039 occasionally
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 03-21-2024, 04:25 PM
Dragncar Dragncar is offline
I went with zero and 1016s and all is good.
Old 03-21-2024, 04:45 PM
Getting to zero or better yet plus .005” gets more of the fuel out of narrow piston to bore gap and where it should be, in the chamber to be burned and not wash the lube oil out of the top of the bore over time.
Old 03-21-2024, 09:28 PM
My machinist told me his recommended minimum is .050 and he said I should put them -.005. I told him to put them at .000 and he said OK. So I just wanted to confirm what I thought I already knew. Thanks for the confirmation. .000 deck will give me 13:1 and that is what I was shooting for. I had him mill .050 off of my heads and got the chambers down to 61cc's.
Tim Corcoran
Old 03-22-2024, 10:01 AM
aaronman aaronman is offline
https://www.enginelabs.com/engine-te...n%20the%20bore.
Thought this might be helpful. I would following your machinist recommmendations.
Old 03-22-2024, 10:05 AM
bluegoat65 bluegoat65 is offline
I m actually .010 out with .060 head gasket on a factory block, running BME alum. rods, N/A motor, lol. No issues.
Old 03-26-2024, 12:14 AM
Probird's Avatar
Probird Probird is offline
I was just kissing the pistons with aluminum rods, zero deck, and a .060 gasket. I do have a small dome though. But I think it probably touched when it over revved breaking a rear end and bounced it off of the rev limiter. I run .075’s now.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 03-26-2024, 01:28 PM
I have steel rods and Butler/Ross flat top pistons
Tim Corcoran
Old 03-26-2024, 03:12 PM
Pontiac Performance Author
I agree with PK and Steve 25. I shoot for .030" piston to head clearance.
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 03-27-2024, 01:50 PM
77 TRASHCAN's Avatar
When Jon Kaase built his Engine Masters engine(s) he went .035 quench.
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
