Does anyone know if a factory size HEI cap will
Does anyone know if a factory size HEI cap will clear the plenum of a Wenzler 1 tunnel ram....first design Wenzler t-ram ...not the Gutsram
Thanks |
Not sure if the rear bottom of the Plenum will clear the top of a HEI ?
It will not.
If it did it would be on my car already. At least for a test fit. When I tried it - no go....cap hit the rear plenum corner and would not slide all the way back. Mine has already been cut and welded on in the runners, so I MIGHT try and clearance the back of the WENZLER. Or spend time/money on a small cap distributor..... that may or may not be as stable as the HEI
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
