Old 01-20-2010, 11:13 PM
ramairthreegto's Avatar
ramairthreegto ramairthreegto is offline
Default Correct temperature sender for a 69
GTO, anyone know the part number.
This is for an idiot light, not a temp gauge.
There seem to be half a dozen or so that might be right
"Yes, it's a real GTO. I know the scoops, spoiler, exhaust tips, and rear wheels are wrong. Umm, sure it's the 'big block' 400, you are quite the expert. I am driving in the rain, at night, running errands, with the kids who are eating and having ice cream in the back, after going to the drag strip, burning rubber, and blowing donuts. Do you really think it's numbers matching all original?"
Old 01-22-2010, 11:00 PM
Pontirag Pontirag is offline
this may or may not help but I was having guages rebuilt and the guy told me that the ohm rating of the sender is whats important not so much voltage. and a very good ground ...as in no sealer or tephlon tape. metal y metal.
Old 01-24-2010, 10:08 AM
shineybike's Avatar
shineybike shineybike is offline
When I replaced thye idiot light sender on my '68 I could not find a sender at Napa for the pontiac. I did find one listed for an Oldsmobile. Worked fine. Sorry I don't know the part number.
1968 Lemans Convertible
Cameo Ivory, Red Interior, White Top
Old 01-24-2010, 11:25 AM
no prob. some of these companies have a lot, but not all have an easy search site. inline tube has it, like a lot of other little parts they have. man, a lot of these companies if they could get real user friendly search set up for their catalog would not have to list on ebay like they do.
Old 01-27-2010, 01:22 AM
yea. I just did a search thru kragen, autozone and pep brothers and what a customer unfriendly nightmare. crearly the websights are desined behind closed doors by a committee of people who take there car to have it worked on. Pep was worst of all.
NAPA was pretty good. CHA-CHING.
Old 02-06-2010, 01:58 PM
sport coupe sport coupe is offline
Default Temperature switch
68-69 All #1993444 Switch (248 Degree) (Exc. Aux. or Rally)
70 All V/8 #6490384 Switch, Eng. Thermo & Dist.
Interesting under the picture of 69-70 auxiliary gauges it shows the group #1.150. But in that group it does not show the same part number for the temperature switch for the 69-70? Can post that group of part numbers that cover all models 59 to 75 if you need it.
Old 02-06-2010, 07:43 PM
wytnyt's Avatar
wytnyt wytnyt is offline
i could use the part # for the '67 400 if you have it handy SC
thx
Old 02-08-2010, 11:16 AM
Default Temperature sending numbers
Here is the list.
Old 02-08-2010, 07:23 PM
wytnyt's Avatar
saved it
thx alot sport
Old 02-08-2010, 09:18 PM
awesome, thank you.
Old 08-19-2021, 08:27 AM
grivera's Avatar
grivera grivera is online now
Originally Posted by sport coupe View Post
Here is the list.
Holy thread revival!!!
Do the sender part numbers cross reference? Not having best of luck looking for a 69 Firebird rally gauge temp sender with spade connector...
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 08-19-2021, 03:35 PM
My guess is that you have a water switch transducer Part number 6490440 that uses the spade terminal. Possible someone converted your cluster from the warning light (with the spade terminal) to the gauge package (that uses the round terminal). It is possible that you current connector has the indent in the plastic to fit either switch. Or someone just replaced the original and put in the wrong switch.
Old 08-20-2021, 08:58 AM
grivera's Avatar
Thanks for the clarification as I didn't realize the rally gauge set up had a button head sender. In my case I currently have a factory idiot light set-up and looking at a rally gauge conversion set up (see link below) which includes a re-engineered circuit board. This is advertised as direct adaptable to a idiot light harness but one needs to use the rally gauge sending units for water and oil.
https://www.ebay.com/itm/133192838467
Will Rivera
