Old 11-26-2021, 11:00 PM
d63howe d63howe is offline
Default Lifters
I have two sets of Summit brand hydraulic valve lifters here purchased in
the '97 time frame. Am wondering when all the quality on these started
to go bad. Not sure if I should even think about using them or not.
Old 11-27-2021, 09:43 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
well just by coincidence....i just found a set of summit lifters I bought in like 2000. once you take one apart you will notice there is a lot of difference between summit brand and Johnson/wolverine brand of the day.
Old 11-27-2021, 03:03 PM
Agree, The Johnson/Wolverine Lifters were some nice pieces even in 2000.
You can assume that Summit was going to the low cost "Alternative Source"
but not sure of the exact time frame.
Old 11-28-2021, 08:04 AM
67Fbird's Avatar
ok...breakdown of the Wolverine lifter. And YES it is right side up on everything except PY Album.
So we have 7 pcs
clip
pushrod cup (that seperates from spacer)
spacer
pintle valve/ restrictor plate (easy to get cocked upon re-assembly)
Inner lifter valve
spring
outer lifter body.
Old 11-28-2021, 08:09 AM
67Fbird's Avatar
pushrod cup,spacer, pintle valve are SHOWN as 1 pc ^^^
So Tom as you mentioned that the RAIV lifters actually had a "special" pushrod cup....i would expect If i wanted to "limit" the travel of THIS lifter I could...actually intall a shim between the pushrod cup and "spacer" effectively increasing the OVERALL stack height of the internal valve assembly; therefore, limiting the internal valves total movement capability??
Old 11-28-2021, 08:16 AM
67Fbird's Avatar
Now the Summit brand circa 1995 ..ish... I do NOT recall exactly but that would be a fair guess.
NOTE: the pushrod cup "ASSEMBLY" is made completely different.
Old 11-28-2021, 10:14 AM
There are two different lifter bodies on the ones I have. One body has a groove toward the bottom of it
and the other does not. looks to me like two different manufacturers maybe.
Have not taken one of either apart. Just wondering when the lifter wear problem started to show its
self. Not sure if I would even use them, still have two sets of NOS GM lifters.
Old 11-30-2021, 07:54 AM
67Fbird's Avatar
and the plot thickens....
upon FULL disassembly of the Johnson/Wolverine lifters it seems there is more there than meets the eyes (at least MINE....)
so there is a small "cap" on the bottom of the internal lifter valve. INSIDE of it is a very very small spring and a valve disc. BEST to NOT remove this as the spring is quite small, thin and invisible unless you are working in a science lab!!!
FWIW...in changing from the "hair pin" clips to INTERNAL LOCK RINGS...the size is 11/16. (seems I read a post that they used 5/8...so thats what I got...nope that would be wrong!))
Old 12-01-2021, 12:16 AM
Schurkey Schurkey is offline
This is a thousand years old, and no longer accurate. But it does show ALL the pieces required, which the photos above do not.
