Old 04-25-2023, 02:38 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Default AFB with stuck secondaries - what do you like to get them loose?
Bought one that looked good, that is, until I got it home and realized the secondaries were stuck fast and no amount of PB Blaster was changing that outcome. #livenlearn.
Picked up another in a deal (a throw-in) from a '58 370, same issue. Ain't no budging 'em.
White vinegar? Coca Cola? Torch? Gotta be something that will get 'em open, can't believe the primaries are fine, and the second pair are frozen when they are made of the same material... know that some of the Medicine Men here must have an answer.
Thanks in advance
Old 04-25-2023, 03:07 PM
Kroil should do it.
Old 04-25-2023, 03:10 PM
Steel to Aluminum corrosion like that is a tuff one.
I have used a liquid product call tap-out.
It’s a acid that will dissolve the steel corrosion, but not the aluminum.
You can also try a 50/50 mix of muric acid and water, but that will eat the Aluminum some.
Old 04-25-2023, 03:51 PM
tom s tom s is offline
I think brass shafts in alu.Tom
Old 04-25-2023, 04:00 PM
77 TRASHCAN's Avatar
The under rim toilet bowl cleaner, but do NOT walk away from it soaking, and forget it. Use for short period of time, only.
Set carb in pail of gasoline, no harm in this....
Shut it off
Shut it off
Old 04-25-2023, 04:02 PM
The choke isn't closed is it?
Old 04-25-2023, 05:14 PM
carbking's Avatar
carbking carbking is offline
I take it apart as far as possible, then put it in an ELECTRIC toaster oven.
Jon
The Following 2 Users Say Thank You to carbking For This Useful Post:
carbking's Avatar
Jon
Old 04-25-2023, 07:41 PM
694.1 694.1 is offline
Evapo- rust will not attack any metal. Worth a try.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
