| 1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out. |
I am trying to determine the VIN of an 83 Trans Am. Water leak completely corroded the number at the base of the windshield. A sticker on the door jamb is completely illegible. I had read that a possible location was on the bulkhead around the rear hatch latch, but I found nothing there.
Any suggestions?
70 Goat 74 Ventura 63 Cat 56 GMC et al. |
The front body support rail, passenger side should have the VIN stamped in.
RPO tag too (glovebox) |
So, under the fender......part of the unibody support structure
Thanks for the reply, Bob. The “glovebox” is just a vinyl pouch attached to the face of the dash. Do you know if the fender has to be removed to see the part of the support structure with the number?
I would think loosened up, not removed.
You should have a RPO sticker, maybe in the back hatch area. Pretty sure you have a small opening for the spare tire. Also - underneath the center console lid, my '84 has it there. And - the RPO list might of not started until 1984. So '83's might not have it (RPO sticker) |
Thanks again. I also found out the data plate (cowl tag) is not on the cowl but on the radiator support. Car is at a friend’s house and I have to get with him to check it out.
