Looking for first hand experience only.
They seem cheap in price? I belive you get what you pay for howerer, are they good enough?? I sure dont want leaking fittings! Working on gathering parts for my fuel system. Thanks. |
I have used both the Jegs and Summit house brands and never had an issue with either one.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
I've used numerous brands of fittings/hoses. Nothing I've worked with did the job easier and correctly than Hyperflow Performance.
The problem i had using Summit/Jegs brand hose and fittings was the nylon would flare out after they were cut and always had to wrestle the hose on using a lube of some sort and that always seemed to leave a pretty weak crimp. That's just from my experience though. You might pay a little extra for Hyperflow, but the assembly will be way easier than you've ever imagined and the company is based out of TX. |
Thanks for the imput!!!
I just got everything from amazon for mine, this cheaper evil energy fittings and lines worked great so far.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
