Old 04-14-2017, 07:11 AM
big matt's Avatar
big matt big matt is offline
Default 1970 throttle cable bracket
Hello. Would anyone have a picture of the correct throttle cable bracket along with coil orientation/ location for a 70, 400 4 speed car? I have misplaced the bag with all my coil/throttle bracketry and now i will buy new i suppose. Looked up pics online but there seems to be a bit to chose from. My car does have a throttle cable with a plastic square block on it that snaps into the bracket. Thanks.
1970 Formula 400 4 speed
2006 Gto. Ls2/m6
1972 Gto 455ho/th400 post coupe
1973 Grand Am 400 4 speed
Old 04-14-2017, 10:11 AM
TA455HO's Avatar
TA455HO TA455HO is offline
Here is a relevant page from the 1970 Assembly Manual. Do you need a copy of this manual? I can send you a ZIP file that contains the PDF - you unzip on your end and save the PDF someplace and you can access it, too. Let me know if you'd like a copy. I would just need your e-mail address. You can send me a PM with that info if you'd like. All 1970 Firebird with 8 Cylinder engine should be the same in this detail, as far as I know.
Click on the attachment to view the larger size.
Name:	Coil and bracket.jpg
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 04-14-2017, 11:28 AM
tonyk tonyk is offline
Here is how mine was when I disassembled it, however its an auto.
Old 04-14-2017, 11:31 AM
Sorry - couldnt figure out how to attach multiple pics.
Old 04-14-2017, 03:24 PM
big matt's Avatar
Thanks to all of you. Much appreciated. Have a great easter.
2006 Gto. Ls2/m6
