Old 05-15-2005, 03:53 PM
taximan's Avatar
taximan taximan is offline
Most guidebooks on trimtag decodes show the build date in a different location. My build date is 05B, and is actually the 3rd line down, on the left. It is slightly below center of the rivet location.
First line - ST 69 242XXXX
Second line TR 258
Third Line - 05B
Is this correct ? I have seen some illustrations that show build date as First line ??
taximan's Avatar
Second line TR 258
Third Line - 05B
Old 05-15-2005, 06:45 PM
trigger0105 trigger0105 is offline
my 69 gto has the date code (06b) down on the third line as you stated. i have all documentation for this car as well,so i would say your tag is correct.
Old 05-15-2005, 07:08 PM
69 RA GTO's Avatar
69 RA GTO 69 RA GTO is offline
Taximan,
Your Build date is in the correct location. I have had 5 69 GTO's and all of my build dates have been on the 3rd line. You have nothing to worry about with your trim tag not being correct. Hope this helps.
www.69judgeregistry.com
Documenting ALL 1969 Judge and Ram Air GTO cars. If you have one of these cars we would love to hear from you
Old 05-15-2005, 07:20 PM
Held for Ransom's Avatar
Before 1969, the built date was found on top. 1969 was when it was moved below.
So long, farewell.
