Old 02-12-2024, 10:56 PM
67drake's Avatar
67drake 67drake is online now
Default Ugh! Think I screwed up my rings
Asleep at the wheel. I was knocking down the corners of my rings and ran a small bevel on the outside edge, not just the corners. Afraid I’ll get too much blow by now.
What do you say, yea or nay?
I’ll gladly invest in another set if needed.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 02-12-2024, 11:42 PM
You’re good.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 02-13-2024, 07:19 AM
That’s ok.
The thing to not do when rounding over sharp edges with a moly face ring is to run whatever your abrasive tool is back & forth, as that done on the face of the ring can flake off the moly.
You want to only make you passes by pushing in to do the rounding off.
Old 02-13-2024, 07:25 AM
67drake's Avatar
Yeah, the top ring is moly, so made sure not to run the file out while filing, just in.
Won’t I lose compression by that bevel, or just not enough to matter?
Old 02-13-2024, 09:41 AM
mgarblik mgarblik is offline
If they all look like the one pictured, I think your OK.
Old 02-13-2024, 10:05 AM
How’s the top and second ring to piston back clearance?
They should not duck into the groove by more then .005”
Old 02-13-2024, 04:27 PM
Dragncar Dragncar is offline
Guys run big ring end gaps all the time with more materiel missing. Engine does not know the difference.
You won't lose a thing.
Old 02-13-2024, 08:42 PM
67drake's Avatar
OK. Went through all the rings and found the one I thought looked the worst, then squared it in the cylinder. This is what it looks like. Obviously some of that is the rounded off corners, but you can see the metal of the cylinder where the bevel is.
I figured only a few thousands was going to be exposed between the piston and cylinder wall, and that’s exactly where the bevel will be of course.
Still OK?
Old 02-14-2024, 06:55 AM
Your still good like that, it will not make a bit of difference when the motor is up to temp .
