Old 06-27-2022, 02:02 PM
JUDGE3 JUDGE3 is offline
Default Holley 50cc fwd acl pump
would changing to a 50cc fwd acl pump be beneficial for most performance applications using a dual plane intake?
Old 06-27-2022, 02:41 PM
tc's Avatar
tc tc is offline
If you have a hesitation while accelerating and believe it is lack of fuel from the carb, then moving the 50 up front is ok. I did that while drag racing, but was fine on the street with the 30 up front and 50 in rear. Now with the smaller cam, I have the 50 in the rear of the carb ( 30 up front ) while racing. I use a dual plane intake.
Old 06-27-2022, 03:32 PM
50cc will give you a longer shot. I also believe depending on the size of the nozel will depend on which you would use, 30cc vs 50cc.
Usually Dual plane manifolds do not need as large of a shot compared to a single plain intake. (smaller plenum)
2007 Grand Prix GXP 5.3L
Old 06-27-2022, 03:36 PM
77 TRASHCAN's Avatar
Have you experimented with the pump cam any???
Shut it off
Shut it off
Old 06-27-2022, 04:00 PM
25stevem's Avatar
25stevem 25stevem is offline
Please note that with a Holley whenever you have reset the idle speed from where you had everything working perfectly, you then also need to readjust the pump spring and it’s clearance.
I do stuff for reasons.
Old 06-27-2022, 05:15 PM
The "30 cc" pump (per 10 strikes) works fine for most street applications on carbs up to 850 cfm. 3 cc-s for ONE carb stroke.
There is some benefit on a "Street Car", that is run on the track with an aftermarket converter, with the "50 cc" pump. 5 cc-s for ONE carb stroke.
Old 06-29-2022, 08:41 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
My combo loves the 50cc pump up front. RPM or TII manofold. 850 dp annular boosters
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 06-30-2022, 08:43 PM
Brentco's Avatar
Brentco Brentco is offline
X2^
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
