found a local guy that can repop the intake.IF,thats a BIG IF,how many would be interested in giving a deposit to have one?There will be one and only one version.It will be a flat floor with stock ports to fit 65 and up heads.It will require a dimpled front cover and would use a tripower or dual quad thermo housing.Will not be RA IV ports.If you buy one and want it larger it is up to you and your porter to do it.Im getting a price to make 12,25 and 50.Im not in it to make money.I only need one for myself and the person that sold me the one I used to make the one im using for the pattern.I know it wont be under $1500 so lets start from there.Could be $2500.PM me or email please.Tom
I'm interested. Sorry Troy can't get used to a Wenzler.
Interested.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. 1966 GTO Hardtop - PS 14.84 @ 97mph |
PM sent
You going to do the water neck too? Or use Tri-power?
Sure you can Bob......Gutsram..
Bathtub repops are definitly a WOW factor but it would cost HP I believe.. Curious of flow capability of repops..but I realize that's not the point.. Cool of Tom to look into repoping.. ![]()
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
As Billie Crystal once said..."It is better to look good than feel good" LOL
Going to bring this to the top again.Had a guy at my house today that might be able to get it done.Just want to get interest from a low of $1500 to a high of $2500.He is making me a spread sheet with how many and how much.The ports will handle a std ported E head and will have a late water Xover(post 1964)will not handle wide or high ports.Tom
Tom many of the ported E heads go 2.3-2.4 tall so at least covering that size hole to seal would be good.
![]() Quote:
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
![]() Quote:
Yes it did,he made less then a DZ of them.He made a couple versions,I did some dyno tests on them and there was less than 5 HP diff from all of them.The molds are in the estate and cant be had.Tom
The manifold in the 2-door Tempest had a "V" plenum and straight runners vs the curved (stock) bath-tub stuff that was hidden inside the intake plenum. I helped Randy W.and Joe Z with the design of the things. Ask Joe Zajac or Larry Kaufman.
Tom Vaught
![]() Quote:
I know of a few NSS guys that want one, they tried to buy one of ours, but $2,000 is out of the league for them. The Victory NSS association will not allow the Wenzler, so they are left with the low profile E or Offy, and the Warrior. Calvin Hill Hill Performance 708-250-7420 |
still have not got the quote,waiting for the breakdown with cost to numbers.Tom
Keep us posted on the cost Tom.
![]() Quote:
IF there is a intake it WONT be the V version!Mine is the flat floor.Tom
looks like without too much work the port entrance could be 2 1/2 by 1 3/8.With welding either top or bottem could be taller,doubt a wide port.Tom
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
