69 gp gas gauge stuck on full
finally took out the gp today and ran out of gas. i thought i filled it three years ago when i put it away. would this be the sending unit float stuck? thanks
I think the trick is to unplug the tan wire in your trunk
Coming from the taillight loom That wire should go to the sender Unplug Turn key on Any difference?? |
i"ll give it a try today. wqhat difference should i see? thanks
If you unplug the tan wire and turn the ignition key to ON the fuel gage should go to beyond full. Then if you ground the tan wire going to the taillight loom the gage should go to beyond empty. If you get both results your fuel gage in the dash and all the wiring from the gage to the connector in the trunk is good. Your problem is either in the wire going from the connector in the trunk to the sender in the tank or the sender itself. That’s assuming you have fuel in the tank.
well i thought i would get to it but plans changed. definatly this week for sure i will update the results. thanks
