Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-04-2014, 07:57 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Default Never Raced McCarty/BES/INDY Cartel RamAir 5 Top End for Sale.
10K
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-08-2014, 08:30 PM
RAIV-Z's Avatar
Includes Head Studs
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-13-2014, 08:23 PM
RAIV-Z's Avatar
Bump
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-14-2014, 09:41 AM
shaker455's Avatar
What size is combustion chambers & what do they flow?
Servicing the Pontiac community over 20 years
Old 12-14-2014, 11:50 AM
RAIV-Z's Avatar
CC Volume is ~80CC
Name:	McCarty-BES-CNC-Pontiac-RA-V FLOW CHART.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-14-2014, 02:02 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Who's flow bench is that on? It's illegible on the attachment. Thanks Ed
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 12-14-2014, 03:18 PM
RAIV-Z's Avatar
BES Racing Engines Flow Bench.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-18-2014, 10:19 PM
RAIV-Z's Avatar
Includes BES Ported Intake with EFI bungs.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-26-2014, 12:00 AM
RAIV-Z's Avatar
Xmas Bump
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-31-2014, 12:10 PM
RAIV-Z's Avatar
News Years Bump.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 03-25-2016, 10:42 AM
RAIV-Z's Avatar
Easter bump
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-11-2016, 06:04 PM
RAIV-Z's Avatar
RA-V 356T-6 Alum
O-Ring Heads
Dry Deck Heads
BES Racing CNC RA-V Head Porting
BES Racing CNC Combustion Chamber
BES RAcing Alternate Intake Valve Spacing
Valve Guides PPP Special "Tool Steel" guides
Valve Spring Cups Manley 42371-16
10 Degree Titanium Retainers Manley 23640-16
VALVE SPRINGS Manley 221425P-16
Valve Locks Manley 13162-8
Lash Caps Nitrosteel Victory VLC-341125
Intake Valves Victory Stainless Severe Performance 2.300 diameter
Exhaust Valves Victory Super Alloy Inconel 1.750 diameter
Intake Valve Seats Special T hard seats
Exhaust Valve Seats Special T hard seats
Single Plane Dominator Intake Manifold w/Injector Bungs
BES Racing Intake Porting
ARP Head Studs
T&D 1.65 Stainless Shaft Rockers w/Spring Oilers and Needle Bearing Tips
Smith Brothers Push Rods for T&D Shaft Rockers
Other parts also available.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-11-2016, 06:24 PM
tom s tom s is offline
Do you know if the deck is thick enough to surface the O rings out and can the deck be wet?Tom
Old 11-11-2016, 10:22 PM
RAIV-Z's Avatar
Hey Tom,
The aluminum plugs can be drilled out to convert them back to wet deck. The o-ring is a .041 stainless wire, the heads would most likely need to be milled .030 to .032 to remove the grooves. I can measure them at a few spots, but realistically Jim Robertson may be the best person to answer this question.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-11-2016, 11:12 PM
Old 11-12-2016, 10:34 AM
RAIV-Z's Avatar
Tom, I reached out to Jim yesterday. He will check the deck thickness on the set he has and weigh in.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-12-2016, 12:45 PM
You may not need to get rid of o-ring grooves if gasket bore is small enough to cover them and not interfere with bore.
Old 11-12-2016, 02:01 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
From my notes back in 2010/2011...deck thickness is .600" on Tom S's heads. Best of luck on the sale.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 11-12-2016, 04:59 PM
RAIV-Z's Avatar
Thank you Jim!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-12-2016, 05:36 PM
Tom S, .032" off the deck of the heads (with a measured .600" thick deck) is a non-issue as far as a "skim cut" on the heads. CCs in the combustion chamber would change by about 4-5 ccs so the compression ratio would go up some though, as you know.
Might actually help on a non boosted engine with improved compression ratio.
