On a '68 LeMans, I've got idiot lights with a Rallye Clock (strange?). Aside from switching out the sensors, what would need to be done to install a Rallye gauge setup and have it function correctly? I guess the correct printed circuit would be needed, but what else in the way of harness, etc.? I'd rather keep the clock and go with an aftermarket tach...
First off you need a Rally gauge cluster with the original circuit board in tact. You need to swap the #5(tan) wire and the #7 brown wire at the back of the guages. On 68's, you must also cut 1 wire and I forget which one. That's it.
p.s. Green wire goes to temp sender, dark blue goes to oil sender.
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
Note ,this procedure is the same up until 72. I've not done any of the later models to know if they're the same or not.Also the light/rally clock is a fairly common thing. I've owned several pontiacs with this combo. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
