Power steering pump pressure
Is it possible for the pump to make too much pressure or not enough pressure.
I have a quick ratio box and my replacement pump. I am getting a belt squeal at 3000 rpm. Nothing before 3000. New pulleys and belts. When I changed the pump I never considered the pressure required. If that is possible. Alignment is correct. Sent from my SM-G930V using Tapatalk
........I'm just learning as I go....... |
Had that problem before,bought a repro power steering belt and that fixed it.
Sent from my iPhone using Tapatalk |
The Following User Says Thank You to DavesGTO For This Useful Post: | ||
My junkyard "research"from pulling pumps and their regulators told me that Bird had the low psi (1100?), A-bodies had medium (1200?), and big cars had high psi (1600?).
Think i went with 1600 psi in one of my birds and it was too twitchy. Nice though in a 68 GTO. |
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Cogged V-Belt is the best remedy for PS squeal.
Is the new PS belt you mention bottomed-out on the PS or crankpulley? |
I will check that. They seem to be seated flush. Remanufactured gm pulleys and gates belts.
When you order a new pump, do you need to be pressure specific? Did I make a mistake? Sent from my SM-G930V using Tapatalk
Pump pressure
Summit sells a kit to adj pressure.
It goes into output port on pump. The kit contained shims to control Bypass volume and thus lowered output Pressure. When I put a new pump in I did not know to Pull old output fitting and transfer to new pump. Kit resolved issue.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
The Following User Says Thank You to 68 Firebird For This Useful Post: | ||
Jim Shea Steering papers regarding pressure and flow rates.
http://jimshea.corvettefaq.com/wp-co...s-09OC2013.pdf http://jimshea.corvettefaq.com/?p=572
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
The Following User Says Thank You to OG68 For This Useful Post: | ||
