64 GTO Wiper Question
Got a 1 speed wiper motor. It was working, now its not. I thought because the dash switch fell apart. Picked up a new switch that has 2 contacts. Can't see where these plug into tho.
Also tested the motor by applying 12v and ground.... motor doesn't work. This is a defintive test for the motor??. I take it that the switch provides ground to the motor. Also tested for continutiy between the wiper harness connector and ground and it reads open. Also my shop manual says the wiper linkage needs to be disconnected under the dash in order to remove the motor.... looked but don't see where. Do see linkage thru the cowl tho. Any help would be appreciated thanks tom |
If it's like my 65, and I think it is, You'll need to pull the cowl vent from in front of the windsheild to gain access to the linkage.
You're correct in the switch grounds the motor and yes you should be able to make it run by applying 12 and a ground to it. It also sticks in my head that the motor needs to be grounded to the cowl by a strap to one of the mounting bolts. be sure this is clean if it's there. Mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
If everything is installed in car check proper terminal on wiper motor for 12V power.
look at wiper motor from front of car while installed. the top terminal on the left side should always have 12V at it. This is the power to wiper motor. the next terminal down can be jumped to ground and it should run the motor. If you have a 64 tempest chassis manual read trouble diagnosis on 11-70 it will tell you all you need to know RTFM!, its your best freind |
Tom, if that switch you got has 2 contacts it could be a 2 speed switch. If it is, go to NAPA and get a 2 speed wiper motor. They are the cheapest for replacements and they WILL work. Stay away from Auto Zone... theirs are junk. I know that as I went thru 4 of them from Auto Zone.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
