67 deluxe interior door handles
Can someone tell me the best way of tightening up the scew that holds the door handle onto the splined latch mechanisim that sits inside the cup used to pull the door to close it.Seems really difficult to access unless Ive got the handles on upside down.
Dave from England |
I finally got tired enough of spending 1/2 hour with a 5/32 box wrench to get that little bolt back onto the splined shaft that I came up with a better solution. My favorite local hardware store had the ratchet-type box wrench that worked like a charm. Not needing the other end of it, I cut it off and smoothed out the edges which allowed it to fit easily within the confines of the cup. Reattaching the door handle was now a 3-minute job.
5/16" actually. Given you're not in inch-units territory, you might look for an 8mm 6 pt version which is typical for a side post battery terminal for which they make cheap ratcheting wrenches.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
Thanks for the correction, Hammered. I was relying on my bad memory since at 5 degrees it's too dang cold to go out to the garage and look.
