Old 08-08-2001, 12:12 PM
Jason Rogers Jason Rogers is offline
I have a 69 Firebird (for sale!) with a 400/turbo400. On the driver side, above where the shift cable mounts, there is a 1/2 diameter round white plastic thingy with a spade connector. What is it? Its leaking and I can't figure out what it is and how to get it out. Help!
Jason
Jason
Old 08-08-2001, 12:39 PM
Held for Ransom's Avatar
It's the kickdown switch. You have to drop the pan to get it out. There are a couple of tangs that have to be depressedin order to pull it out. There is also an electrical connector that needs to be unplugged.
So long, farewell.
Old 08-08-2001, 04:00 PM
Do you have to drop the valve body as well? If that's the case, then I might wipe it and shoot it with silicone to make the mofo stop leaking. I am not dropping the pan again, although I do have a drain plug now....
Old 08-08-2001, 07:47 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
You can get it out from the outside , then if you are not using it just put a freeze plug in it.
