I am changing the Holley on my '72 GTO back to an original QJet. One problem, I can't find mounting studs anywhere. I plan on getting some threaded rod and cutting off what I need. I just need to know what size threads are used for the studs. Does anyone know? Thanks!
______________________________________________ 1972 Pontiac GTO 400ci TH-400 (restoration project) I know what I like, and I like what I know! |
Most carb studs are made with 5/16-18 coarse thread on the bottom to thread into the intake, and 5/16-24 fine thread on the top to attach the carb.
Buy some 5/16-18 coarse thread rod to make your own studs.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
Thanks!
you probably already know this, but if you put a nut on the rod before cutting it and then unscrew the nut after the cut it will help keep your threads in usable shape and prevent cross threading.
"Second place is the first loser""That's no oil leak....that's just sweat from all that horsepower." |
