WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > General Forums > GTOG8TA.COM Late Model Stuff
GTOG8TA.COM Late Model Stuff New products, updates, and other GTOG8TA.COM info.
Old 07-29-2014, 12:47 PM
Jason Rogers Jason Rogers is offline
Default Drive Shaft center bearing
My understanding is that PY is producing a center drive shaft bearing replacement. Has anyone one used this and what is involved? Press?
I've torn (2) and I'm thinking of either going DSS 1 piece (if I can find one) or this replacement.
Old 07-29-2014, 04:40 PM
60man's Avatar
60man 60man is offline
Hey Jason !!!! What car? You have a pre 61 big car? If so the bearing alone is available at NAPA & Steel Rubber Products will redo the rubber for the support itself...
Where ya been........
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 07-29-2014, 04:42 PM
60man's Avatar
Whoops...do the later model GTO's use a 2 piece shaft??
ECM member.
MANDRA
Old 07-29-2014, 06:35 PM
Sirrotica's Avatar
Yes Troy, they do.....................
I was considering ordering the PY part however before I did I decided I would try repairing it myself with some stuff I had lying around. Needless to say my fix worked so I never ordered the PY part.
If your not able to fabricate up your own rubber replacement mount for the carrier bearing the PY carrier assembly is a really good alternative and the least expensive way to repair and save your 2 piece driveshaft.
I took a sidewall out of a truck tire and replaced the rubber with that, It should outlast the car, and the price was right, free. Took a little welding and brainstorming, but I should have no further problems. The rubber that Holden used is pretty soft and thin. No press required, PY has a you tube video that shows how to take it apart with a vise and a hammer. The bearing is a standard part # that my local bearing supply had in stock.
Anyone that has had the driveshaft out of a new GTO I can't believe how small diameter the tubing is. The wimpy U joints look like the kind that are used in a PTO shaft, they're really small considering the powerplant in front of them. The rubber biscuit isolators on either end of the shaft are a problem too, especially the cars with stick shifts that are driven hard. Mine are starting to wear out, but I have an automatic so there is less strain than someone that hammers on a stick shift car.
The only other alternative is a one piece aftermarket driveshaft for around $650. The one piece also addresses the rubber isolators (similar to steering rag joints) on either end of the shaft and eliminates them to be more like a conventional driveline that we're more accustomed to.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-30-2014, 09:57 AM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
Jason,
We are carrying replacements...They are not reproductions. They are actually from GM's source in Australia.
Here is a video or a quick how-to. I've heard people get this done in 15 minutes. Don't rush though
http://www.youtube.com/watch?v=7lDr0-Jx8Fc
If you are thinking about changing the bearing, look at the two rubber discs on either side and make sure they are fine as well.
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
Featured Vendors
Advertising Info
