63 LeMans Progress.
Slowly making headway on the 63. A few photos.
Looks nice.
Looks good and going to be a fun ride.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Looks great keep the posts coming with it
Sent from my Pixel 3 XL using Tapatalk |
Nice project, Is this going to be a back half car (tubbed)
I ran a 4-speed in my 62 for a while, It'll be fun for sure. Keep the pics coming. GT. |
3.50 9" posi, no tubs just the biggest tires I can fit under it.
That's cool, Another guy on here got a pretty big tire under his.
It was like 12.5 or so with the right back spacing. It was R70 judge. Look up one of his old post. Looking good and a 4-speed too. GT. |
I ran 28X10 MT full slicks with a 57-58 pontiac rear and no tub or surgery.Tom
I'm going with the 428 with ported 62s and a 9" with 4.11s. 200r4 for the tranny
I would have run an automatic but I got such a good deal on a M22 Muncie I couldn't pass it up. What offset are you guys running with stock wheel wells?
Update, finally got the four link completed, New wiring harness is next. Also went with 275x15 BFGs. The fit dead center with 4" backspace Weld wheels.
It looks like the front end of your upper bars of the 4 link are higher than the rear at the axle. That will cause wheel hop on hard acceleration. Try to get the front of that upper bar lower than the rear of the bar.
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
Thanks for the tip, I plan on getting ride height set after I get more weight on the car. Its pretty light right now with nothing in it.
When you painted black on frontend did you spray? Brand of paint? Noticed discs on back, brand? Thanks looks good.
Black is just krylon from a rattle can. Brakes are kit from Classic city auto glass, you get rotors calipers adapters brake lines and emergency cables for $300.
Thank you. I bought scarebird s front discs. He has rears for my 57 Olds rear, but different rotor stud pattern. I guess I could redrill.
Body shop finished the floor in my car this week. Didn't need the braces.
Getting some work done on the body. Really hard to find a body shop thats not a year out.
The Following User Says Thank You to hobbygto65 For This Useful Post: | ||
Looking good! Any progress is good progress, as far as I'm concerned.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
