Old 12-23-2023, 02:03 PM
mike76 mike76 is offline
Default Will this proforged center link fit my Firebird?
I have a 76 Trans am and need to know if someone can verify that Proforged 106-10067 fits the car. Visual inspection looks the same and I have the original still in the car. Thanks for any help! Mike
Old 12-24-2023, 08:46 AM
Kenth's Avatar
Kenth Kenth is offline
Looks like it does:
https://www.holley.com/products/susp...arts/106-10067
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-24-2023, 10:51 AM
The Camaro link has a curve on the side of the idler arm as the Camaros use an idler arm shorter than the pitman.
Old 01-09-2024, 07:47 AM
Formula8's Avatar
Formula8 Formula8 is offline
You will need to use both the Camaro Idler and Pitman. Good news is they generally are cheaper and as the Camaro pitman is longer, it quickens the steering. PTFB sells the drag link and pitman together as their "quick steer" kit. I would link you in to their site but it sucks and has been under "development" for about 2 years now so........
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
