LS Talk All things based on the GM LS platform engine
Old 10-05-2023, 07:39 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Default LS Guys.......
Saw this in OC yesterday, guy did a really nice LS swap that would fool a lot of people. Not my thing obviously, but it was VERY well done.
ID:	621017   Click image for larger version
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following 2 Users Say Thank You to OCMDGTO For This Useful Post:
Old 10-05-2023, 07:43 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Very clean!
Old 10-05-2023, 04:50 PM
grandam1979 grandam1979 is online now
Looks great.
Old 10-05-2023, 04:54 PM
Tim john Tim john is offline
Well presented, not a fan of the creature head on the air cleaner but the engine looks right at home.
Tim john---
Old 10-05-2023, 05:11 PM
Here is a 1973 VW Squareback that belongs to my friend. It’s equipped with a ‘99 LS1 and 4L60E from a Corvette and has a tube chassis with a Mustang II front suspension and a 3.70 geared Ford 9” with ladder bars. The air conditioning works pretty well and it gets around 21 mpg.
The car weighs in right around 2500 pounds and with traction it should run mid-11s, the engine is stock.
ID:	621083   Click image for larger version
ID:	621084   Click image for larger version
ID:	621085   Click image for larger version
ID:	621086   Click image for larger version
Old 10-05-2023, 11:52 PM
1966Lemans's Avatar
1966Lemans 1966Lemans is offline
I'm gonna have to see if I can track this car down, tomorrow or Saturday. My 400 is on it's last legs (almost no oil pressure), and I'm looking at all options.
'67 Piper Cherokee
'66 Lemans
Old 10-06-2023, 12:21 PM
OCMDGTO: did you note if that was carb or throttle body injection?
Old 10-06-2023, 12:24 PM
65madgoat's Avatar
Well this should give you LS guys something to shoot for. A Pontiac I feel has to have Ram Air. This hits the mark....
The Following 2 Users Say Thank You to 65madgoat For This Useful Post:
Old 10-06-2023, 12:32 PM
like this?
Old 10-06-2023, 03:46 PM
Does anyone know if the serpentine setups in posts 1 and 9 are stock or aftermarket?
Old 10-06-2023, 05:37 PM
OCMDGTO's Avatar
Scare, I'm pretty sure it was EFI
Here's another I saw in a TA
Chris D
Old 10-06-2023, 06:08 PM
To be able to use a stock air cleaner would be beneficial; ie Shaker hoods, Ram AIr, Cowl Induction etc. for LS/LT swaps.
I wonder if they ran a speed density tune as there is no prosion for a MAF sensor?
Old 10-15-2023, 09:54 AM
72projectbird's Avatar
72projectbird 72projectbird is online now
Do they make an adapter for the Pontiac covers, or are people just drilling and tapping sbc swap brackets?
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-15-2023, 06:30 PM
PDC PDC is offline
Default 73 LS9 TA
Here’s where I am at this point - after re-routing AC and Coolant lines up and under passenger fender and IC pump / front light harness up and under driver’s fender. Looking for clean coil covers now…
ID:	621743   Click image for larger version
ID:	621744   Click image for larger version
Old 10-16-2023, 05:58 AM
JSchmitz's Avatar
Very clean. Nice job!
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 10-16-2023, 06:03 AM
JSchmitz's Avatar
Holley makes Pontiac style coil covers. Not sure why they don't list polished version anymore. Only show natural.
https://www.summitracing.com/parts/hly-241-191
https://www.holley.com/products/ls_p.../parts/241-190
Old 11-20-2023, 08:07 PM
PDC PDC is offline
I really want those polished ones for my car. Likely gonna require some ‘massaging’ to clear my alternator - or a different accessory drive to relocate the alternator. But those just look so clean and so nice!
Old 11-21-2023, 06:37 AM
JSchmitz's Avatar
I have ICT brackets on my engine. The alternator charging stud is very close to the factory valve covers. I cut it down a little. Might be a problem with the Holley coil covers.
Old 01-11-2024, 09:23 AM
KSZR KSZR is offline
Nice. And still multiport injection I believe.
