Old 03-19-2011, 07:56 PM
Johns400 Johns400 is offline
Default Concrete Epoxy Paint/Coating
Just finished building a new shop and was thinking about coating the floor with some sort of epoxy product like U-Coat it. (I've heard nothing good about U-Coat it so I wont be using them but used them as an example )
So I was looking for some real world experience from some of you guys that have done this. I was looking at Armorclad http://www.armorcladepoxy.com/, saw POR has a kit (have always like there stuff) and Wolverine http://www.alphagarage.com/ has some nice stuff but Im not sure Im willing to pay $1000. $500 +/- maybe but not a grand. I know RustOleum has some stuff as well but just cant see it holding up real well.
So if any one can chime in and let me know what worked or didn't work for them I'd appreciate it. Thats guys
Old 03-19-2011, 09:18 PM
paint guy paint guy is offline
Johns400: although a different division, the company I work for makes 1000's of gallons a year of epoxy floor coating. here's some general guidelines: New concrete should age at least 30 days before you coat it with any product to allow the moisture out and let the concrete cure. If you are unsure if your floor is dry enough, tape down a piece of plastic (airtight) overnight. When you pull it up, there should be NO moisture, if there is, your concrete is still too wet. A lot of companies will suggest using muriatic acid to etch the floor, but your best bet (BY FAR) for long term adhesion is to scarify it (shot-blast with steel shot, machines are available for rental). The best systems will recommend a urethane topcoat over the epoxy, and there can be a BIG difference in the quality of the products (not just the solids, either, but the quality of the epoxy resins used). If there is a curing compound or sealer present on the surface of your new concrete, this will have to be removed (scarify). I have seen these products last many years, and the same products fail in short order,because of improper prep and/or mixing, or hydrostatic pressure (concrete too wet). The 100% solids systems are typically the most expensive, but you will use less. If you want more technical advice, the Tech. Director of our concrete division and I deer hunt together (personal friends). Shoot your questions to me and I'll ask him monday or Tues. Hope this helps.
Old 03-19-2011, 09:38 PM
Doing what research I have that seems exactly what i need to do. The floor is also plumbed with pex for radiant heat (not hooked up yet) but it should help with future moisture which I heard could be a problem.
Never heard of the shot blast system. By the sounds of it, its a sand blaster of sort w/a different medium? Ill check in to it. How important is the primer coat? I planed on getting a kit that included everything minus the primer so I wasn't sure how critical it was. Common sense would say yes lol.
Old 03-19-2011, 10:31 PM
A scarifier is a machine that uses steel shot to blast the floor. There are some that actually blast the floor and then will recover most of the shot at the same time. You will still have to vacuum/sweep up the rest. If the product line your considering suggests a primer, there is a reason for it, that is how they designed thier coating system. I would follow thier recommendations. No matter what you are painting, the cheapest part of virtually ANY paint job is the paint. Don't know what part of the country your'e in, but moisture retention (and the 30 day suggested guideline) can vary greatly with weather conditions. Good luck with your floor.
Old 03-20-2011, 08:50 AM
Paul E Paul E is offline
+1 on paint guy
Find a local company that does this commercially and buy some from them. If you need to walk on it while doing the application due to layout, find some OLD golf spikes at goodwill etc. I used acid to etch mine and it worked very well, 10 years later no issues. Also if you weld put a thin sheet of aluminum under the area so you do not burn it and teh slag will fall off. Had my piece for years. also do not mix and leave in container, pour it on the floor or it will hold heat and set fast.
Paul
Old 03-20-2011, 10:29 AM
LOL those things remind me of a drum sander for wood floors. Im not sure I would trust myself with one and that pretty new concrete.
Good call on the local Paul, found a place in town. Now to see if they will just sell me the product. What did you use if I may ask?
Old 03-20-2011, 10:42 AM
RedDirtRoad RedDirtRoad is offline
What did your hear bad about U-Coat it?
I have that but havent applied it yet.
Old 03-20-2011, 11:06 AM
That its goes on really thin and doesn't cover well. I guess you could put it on thicker but have also heard it doesn't hold up well, which could mainly be due to being thin.
Old 03-20-2011, 01:44 PM
65 Cat 2+2's Avatar
65 Cat 2+2 65 Cat 2+2 is offline
Someone I know used U-Coat It on a new concrete floor. After a short time it lifted in spots. He tried to get the company to make good on the warranty, but the "fine-print" conditions made that impractical.
1965 Catalina 2+2 421 Tri-Power, 4-speed, all original except paint -
AACA Grand National Sr. / POCI Champion - 13.71@104mph 1/4-mile
1958 Bonneville convertible - AACA / POCI survivor awards
1963 Catalina 2-door hardtop - 10.91@124mph 1/4-mile
1933 Pontiac 2-door Sedan street rod project (in progress)
1962 Corvette 327/340hp, all stock
1963 Studebaker Avanti
http://www.1965Pontiac2Plus2.com
http://www.Pontiac2plus2Registry.com
Old 03-20-2011, 04:04 PM
I used a primer coat and then a grey 2 equal part epoxy. About 10 years ago. dump on the floor and then squeege around and let level. Was pretty easy
Paul
Old 03-20-2011, 08:42 PM
ERIC AULL ERIC AULL is offline
I had http://www.garagetek.com put a "polyaspartic resin" on my floor. BEAUTIFUL, STRONG and a bit expensive.
The Following User Says Thank You to ERIC AULL For This Useful Post:
Old 03-20-2011, 09:06 PM
ry57pont's Avatar
ry57pont ry57pont is offline
i used rust oleum professional, i bought it at menards. going on three years of abuse, winter salt, jackstands, ect.. i acid etched the floor and put two coats of color, two coats of clear. so far i am super impressed with it - RB
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 07-16-2026, 08:21 AM
I had a company come in and do my garage floor before I moved into a newly built house. They did a moisture test, and did a 'hybrid' multi-coat, using an epoxy 'blend' and top coat of polyaspartic resin.
They prepped the floor with a diamond grinder, no primer, then applied the epoxy. They allowed it to cure to a certain point before adding grey/white/black flakes, then coated with resin.
True on the 'not cheap', and I shopped for weeks with quotes all over the place. As an example, for a 26x24 slab, it ranged from $2500 up to a breathtaking $16k. I ended up paying $4k, which was in 2022 money. Especially considering the amount of prep work there was.
I beat the heck out of it, and it's taking the punishment, so am satisfied and not regretting the cost.
One thing I will point out though, with the flake, if I drop a screw/bolt/nut/washer, it can take a half-hour to find it, even if it's right at my feet! Heheh! Most of the time if I put my cheek to the floor and look at floor level, I can find it, but if you're planning on doing a lot of work in there, I would suggest a solid color or at least something that provides some contrast.
EDIT: Make sure you give it ample time to cure, and then wait another few days!
Old 03-21-2011, 12:26 AM
bdk1976 bdk1976 is offline
Click on the following link and then go to the Flooring subforum or do a search on floor coatings - you'll be reading for days (and may or may not be more confused than when you started):
http://www.garagejournal.com/forum/
Old 03-21-2011, 02:04 AM
torqjunki's Avatar
torqjunki torqjunki is offline
I used the Rustoleum product as well purchased at home depot. This was on new concrete. I allowed some time for curing, don't remember how much, but whatever was recommended. I followed the procedure to the letter. Single coat and threw out some paint chips that came with it for looks. I should point out that this is a shop that I planned to work on cars in. I did not build it to impress my buddies or to stand around and bench race. I use jack stands, floor jacks etc. I spill stuff and don't clean it up immediatly. Going on close to a year now and it has held up perfect. When I finished and stood back and looked at it, I thought it looked like crap. You must over lap to cover it complete and these areas show up when there is nothing in the building. By the time I let it dry and got my car, tools etc in the shop, you can't see any variation in the coating. Bottom line...if you can do it yourself, and your not building a showcase for your car to sleep in, you can do it somewhat affordably by using rustoleum and it will perform as advertised. BTW...I had the "light broom finish" done on my slab which allowed me to use this coating without any sand or anti-skid added which I believe makes it more durable.
Old 03-21-2011, 09:40 AM
LMAO ya thats for making it even harder. I did find some good stuff over there, one idea I never really thought of was porcelain tile. One guy on there says he has dropped all kinds of heavy **** on his, along with rolling creepers, jacks and engines stands over it with no problems.
Also talked to Legacy Industrial about there product, says they have been doing the industrial side of this for 20+ years and just decided to make up a kit for the DIY. There kit is $500 for almost 700sf. Includes primer, base, sprinkle, clear, and all the other little stuff.
But I just cant get the tile out of my head. Even if a piece breaks I can just pop it out and replace it. Anybody with tile garages out there?
Old 03-21-2011, 09:42 AM
BTW this is a shop that I will be working on my baby in, (72 GTO) not a place for old people to hang out and talk about the glory days lmao
Old 03-21-2011, 11:41 AM
JTT99's Avatar
JTT99 JTT99 is offline
After I built our new home in AZ in 2004 I used the U-Coat It with the clear coat on the virgin concrete floors. I followed the directions completely and can report 6 years later it has held up perfectly with no lifting etc. even in our heat. I built another garage in 2007 and was going to do the same but found I could get the job done professionally and the difference in cost was only about $100 and that was for 750 sq. ft. so that was a no brainer. Given the state of the current economy you might be surprised how close to the material cost a professional may come in cost. One tip for those with these floors. I found the best way to clean is to get a Hoover Tile scrubber/vacum. I found one on Ebay refurbished for less than $100 and it has been money well spent. Makes cleaning really quick and easy.
Old 03-21-2011, 08:54 PM
ry57pont's Avatar
one of the things i remeber about surface prep was to tape a clear plasic sheet roughly 1'x1' on the concrete sealing it to the floor, check it after 24hrs for moisture under the plastic. if so the moisture may "hydraulic" the epoxy up from the concrete.-RB
1962 corvette
Old 03-27-2011, 07:43 PM
PurplePackFan's Avatar
PurplePackFan PurplePackFan is offline
Default Epoxy Concrete Floor Coating
I agree with what all the others said. I did my floor about three years ago with Epoxy-Coat which I bought on line here: http://www.epoxy-coat.com/
I feel that it is a good product, however, they recommended to prep the surface with muratic acid reduced to 1:4. That is NOT enough to rough up the surface, I even made mine about 1:2, but my finished concrete was way too smooth. Someone above said to have the concrete finishers do a "broom finish" to the concrete. I whole heartily agree. My surface ended up being too smooth so the product is not adhereing as it should. I may need to redo in a few years. With epoxy floor coatings you can go as thick as you want as they don't "dry", they "cure" so if you have a rough surface just apply thick enough so that is smoothes out and let it do its thing and you will have a great looking and durable floor. Prep work is everything, the actual application is actually the easy part. Kinda like any other paint job. Start with a clen, rough surface, mix per instructions, lay it out and let it settle, spinkle color chips and let it cure. Done.
Just my $.02 Good Luck!
John
John
'67 Corvette Coupe 327, Tremec 5 Spd-SOLD
2010 Camaro 2SS-Traded
2015 Z51/3LT Corvette Stingray, Laguna Blue
'67 GTO, 428, tripower, RS 600, finally done
