Old 05-09-2014, 02:34 PM
60man's Avatar
60man 60man is offline
Default Hydraulic rollers/racing..
Just throwing this out. Just curious how much over the nose pressures and lift are considered max for a hydraulic roller ?? I know there will be at time to calm down my car but still want performance on track....without a whole lot of maintenance. Birddogging the valve train is top of list.
I know Luhn is working on some HR stuff but would like some hands on info..
Also interested in pump gas/E85 use with HR cam.
Thank you
ECM member.
MANDRA
Old 05-09-2014, 02:59 PM
tom s tom s is offline
Comp told me 180 on the seat,did not ask open.Tom
Old 05-09-2014, 03:18 PM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
The Morel HR lifters I put in my big "Big Chebbie" are advertised to be good to 200# or so on the seat and over 500# open. Overkill for what I am doing, but if they will survive that, they shouldn't break a sweat at 140 on the seat and 360 open.
Old 05-09-2014, 07:34 PM
60man's Avatar
Thanks for replies...
My SR open is 980'ish....guess that answers my question??
I gather the lobe profiles will be different so maybe pressures will be different too as related to lift and ramp speeds..??
Anyone using Johnson lifers??
Just wondering..
P-Dude ...ya out there??
ECM member.
MANDRA
Old 05-10-2014, 09:36 AM
PONTIAC DUDE's Avatar
Thumbs up FWIW:
When I ran my 260'[email protected] Hyd roller I ran 150 seat with 405 open and at Virginia on spray, 7000 rpm thru the traps it ran perfect.
I set Butchers up the same way.
I use the Beehive springs/titanium retainers as you can use less pressure with better valve control. Well Worth the extra money. Easier on parts too.
Old 05-10-2014, 11:51 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by 60man View Post
... My SR open is 980'ish...
Seriously? The heavy valvetrain in my hemi only needed about 650 lb. open to run 9,000 RPM.
Old 05-11-2014, 12:22 AM
60man's Avatar
Thanks Dude...
Yes Jack. Seriously....370 seat
ECM member.
MANDRA
