So I've been going crazier then normal trying to get my oil pressure where i want it (I've had my pan off 3 times. I changed my oil pump to the Butler Pro 60 psi pump and been fighting it for 3 days now. Its a GOOD pump thats not the problem it just differs from all the other pumps I've used specially the pump I just took out. Just trying to get good pressure at idle and 70 psi in the end. Its just crazy how different oil pumps can be that have the SAME cast housings and springs. Don't know how the guys without tube chassis /and or not a two piece old pan do it! Thank Gosh I have a hoist!
GTO George |
I'm about ready to go back to a Mellings pump!
GTO George |
Cool story?
The Titan is adjustable and doesn't need a 2 piece pan, just put a plug in the side to adjust the pressure. You would need a modified pan in order to fit the pump in though.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
455 SD's were 80 PSI
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
Change regulator spring or shim it or modify spring cap so you can make it adjustable.
GTO George |
You should have shallow cover, smaller diameter ball, and purple spring stock from Butler. Then if you add a spring washer shim to that set-up you should be able to bump the oil pressure up even a bit more. Tom V.
in two parts. A longer (higher pressure spring) and a longer spring housing. Last time I bought the stuff from Melling The housing was about $2.00 and the Spring $3.00 Rest of the pump is IDENTICAL. Tom V.
That's right, so why buy a 60 PSI (probably at more money) if you want 70 or more?
![]() George just buy the good Melling pump and worry about other stuff.
This might be of interest:
http://www.luhnperformance.com/pontiac.html A fwiw, I was recently told of a issue with a modified oil pump sold by Butler. And it was discussed with and confirmed by someone at Butler Performance. I do not have specifics if it was their Pro pump model. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 07-09-2017 at 06:34 PM. |
Those look like a great pump, more volume and bigger intake pipe.
GTO George |
The Luhn Pump has a lot of pump features not found in your basic Melling Oil Pump stuff.
In George's case he probably is not spinning the pump high enough, Steve, to get into cavitation of the inlet but the other features are all really nice. I have two of his modded pumps. Tom V.
As you know, more to oil pressure than just the pump. Did you change bearings, or grind the crank? Also, if you want a little more psi, you can run a little heavier oil.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
GTO George |
The purple spring for the melling pump is a 70 psi spring, the yellow is 60 and then you have the longer purple with its extended housing that's 80 psi. All cast oil pump housing are the same.
GTO GEORGE |
I don't normally hang around the race section but what about the Precision pumps?
http://stores.precisionoilpumps.com/pontiac/
The More People I Meet, The More I Love My Dogs! |
Luhn Oil pump.
53 psi @ 7800 RPM. 960 HP. Bearings look new after teardown
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Well HELL thats interesting! GTO George |
