Old 05-09-2010, 08:45 PM
mechanickeith's Avatar
Default Mickey Thompson "Tempest" 2 cylinder!
Here are the pics I took of the Blown Tempest 2 cylinder!! Enjoy!
Note the brackets on the front of the head & block with one bolt holding top & bottom brackets together. This was added later in this engines developement. I never saw it on early pictures.
Blowoff valve on top of intake manifold.
1 barrel Hilborn injector.
The famous (or is it infamous) 2-71 GMC Blower.
Half an oil pan!!
Fuel pump driven off of the back of the blower.
Notice the degree wheel on the base of the mag!
Another shot!
Half a valve cover. Only 2 bolts holding it on! You can see the line on the cover where it was cut & welded back together.
Is that a 538177 head number??
Another shot of the clamp assembly on the front of the motor.
Check out those exhaust pipes!!!
Here's that old fart again!!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-10-2010, 03:06 PM
TIN TIGR TIN TIGR is offline
that is neat..
