The dipstick tube in my TH400 leaks out fluid, when engine is not running.
Here's the history: I decided to check the fluid level. First checked it before starting engine. It showed above the full mark on the stick. But, I've always read that it must be checked while the engine is running and the fluid is warm. So, I checked it that way. There was no fluid showing on the stick, at all. I added a quart, which just barely showed on the stick. It took aprox 2 1/2 quarts to get up close to the full mark. So, I assumed that the guy who installed it had just not put in enuff fluid. But, the next day, I noticed a puddle of fluid under the car. I put a catch pan under it. Over the next couple of weeks it appeared to have leaked out just about all the fluid I'd put in it. ![]() I assume it has the correct dipstick for the tube. I was gonna pull the tube and check the o-ring & groove, as well as the length of the stick. But, the bolt that attaches the tube to the bell housing is too close to the firewall to remove. So, I'll either have to move the engine/trans forward, or just cut the tube lose from the mounting bracket. Anyhow, I'm considering just replacing the tube & stick. I've seen quite a few stock tubes which cracked in the O-ring groove & caused a leak. So, I'm considering an upgrade. One I'm considering is this TCI, which appears to have a much better sealing system than the stock, single rubber O-ring. I think they are called "top hat" seals. https://www.summitracing.com/parts/tci-743803/overview/ But, the description says it is not recommended for tight clearance apps. "...These are not recommended for vehicles with minimal clearance between the bellhousing and firewall or transmission tunnel..." My '68 Bird looks to have only "minimal clearance". So, my question is: have any of you guys used one of these in a '68 Bird ? ![]() I'm also considering one of the cheap flexible tube models, which attaches to the firewall. But, it seems to me that if it has a solid attachment, the engine movement & vibration would make that type tube not the best choice. Anybody use one of these firewall mounted tubes ? They appear to have 2 rubber O-rings, instead of just 1. So, I assume they would seal better than a stock type tube. There are some models that bolt to a Chevy bellhousing. But I haven't seen any that will bolt to a Pontiac bell. So, a question is, if I decide to try one of the flex tube models, would it be best to try to rig up some sort of a block or bellhousing attachment for it ? Or, do some of you guys know of a reasonably priced flex tube that is made for BOP engines ? I found some Lokar tubes, for what I consider a ridiculous price. Don't know if they are any better than the cheap ones or not. Not gonna pay $100 for a dipstick/tube. I only wanna buy once, and not have to experiment, to find one that works. Any advice on a positive solution for my problem ? http://www.ebay.com/itm/STAINLESS-FL...X-DlMg&vxp=mtr http://www.ebay.com/itm/GM-Turbo-350...3D272286553265 http://www.ebay.com/itm/Lokar-Hi-Tec...3D200720316647 |
The stock tube can be converted to the multiple lip seal set-up. We do this to all TH350 and TH400 transmissions built here.
The modification is nothing more than cutting the tube and MIG welding or brazing on a new end that accepts the multiple lip seal......Cliff
" The stock tube can be converted to the multiple lip seal...cutting the tube and MIG welding or brazing on a new end that accepts the multiple lip seal..."
Thanks for the info ! But I don't do any MIG welding, and can't make one. Do you sell the tubes with this mod ? If so, what would be the shipped price ? Last edited by ponyakr; 01-15-2017 at 03:29 PM. |
Does it have the seal that looks like a top-hat or an o-ring? The top-hat seals are great.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Yeah, from what I've read online, the top hats provide the best seal. Mine is a 40+ year old tube, with a single rubber O-ring.
Never give up your original auto trans dipstick tube, that tube is the only tube configuration that will fit your application. The aftermarket 'replacements' are a joke and I'd be surprised if they would fit any car with a firewall. The factory tubes are all very application-specific and there are few if any substitutes that will work.
Find a local welding shop to do the welding, or mail it out to someone who can add the new lip seal end to it.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
"...Find a local welding shop to do the welding, or mail it out to someone who can add the new lip seal end to it. "
I have no idea what size or kind of tubing needs to be added. If this is such an easy & common mod, there should be some Pontiac guys here who have these for sale, for a reasonable price. There are certainly plenty of old Birds out there that could use one. |
I had a pile of tubes and sticks that didn't fit the 442, and many even specifically stated they were for it. That ATI one I think is one that I used, and I used a TCI one on the 4L80E. Had a similar problem finding a tube & stick for it as well. I honestly have never seen any of those 'FitzAll' ones, but in my experience, those type never fit either! The tab needs to move A LOT to be able to change to a BOP pattern from a chebby one, and if it does move that much, it's going to be fugly. (may be hidden anyway tho)
Find a later style GM dipstick tube that uses the improved lip seal.
Cut off the part that accepts the lip seal at the very end of the tube. Discard the rest of the tube, you only need the bottom end of it. Carefully measure yours and cut it so it will end up same length as before, where it seals to the trans case. Cut and fit and have it welded up by someone who's not a hack. This is what I'll do with my TH400 tube and stick that I found fits my '64 Le Mans that never came with a TH400, the tube/stick assembly that works came from a '69 GP. It's hard enough to maintain proper identification of all the tubes one might have in a parts collection. Having a variety of them properly identified, already modded and waiting for sale really isn't practical from a business standpoint. Modding your own isn't that difficult and is practical because you already know it's made to fit your particular car and trans.
"...Find a later style GM dipstick tube that uses the improved lip seal..."
OK, but I've never even seen a tube with the top hat seal. So, exactly what years & trans types came with one of these tubes that I need ? ![]() Maybe I just need to ask my local trans man, who is also a Pontiac guy. I reckin if you make a living building transmissions, you should know about dipstick options, huh ? Maybe he has done the mod ya'll describe. Just thought maybe as many Pontiac guys as there are here, some would have used some of the ones I mentioned, and could relate their experience with it. But, if having my tube modified is the ONLY way to stop the leak, I reckin I'll go that way. Gotta keep the fluid in the trans. |
BUT...while looking on eBay, I found this!!! It's a lower tube repair kit. You cut off the bottom of your tube and install this metal conversion sleeve which converts your tube to a top hat seal. Look here: http://www.ebay.com/itm/Dipstick-Fil...uiPt9w&vxp=mtr
Steve F. |
Now the question: has anybody here every tried this, or know anybody who has ? If this really works, looks to me like it should be almost standard equipment for all the old single O-ring type tubes. No welding--no leaks--keep your original tube that fits the car. Sounds too good to be true. ![]() Yeah, I think it WAS too good to be true. I reread the ad. It says ATTACH the metal sleeve. I assume that means weld, braze or whatever. I was initially thinking slip-fit. But it's the hat that "slips" on. Oh well, you get the end & a seal, and won't have to cut an end off another tube. If I decide to try this instead of a flex tube, maybe I can get a friend to weld it on for me. Here's the end & seal a bit cheaper. http://www.ebay.com/itm/Chevy-350-Di...3D252263551944 http://www.fitzall.com/K35999R.php I just can't help being curious. Since the same size seal fit so many different transmissions, is there not any of the later tubes that would work in a 1st gen Bird ? I mean how many possible different firewall shapes could there be. Looks like there would have to be at least one that would be close enuff to work. Last edited by ponyakr; 01-16-2017 at 12:05 PM. |
Hey, the more I search, the cheaper this fix gets !
![]() http://www.ebay.com/itm/Filler-Tube-...3D122300052435 This is the only brand I've found. It's FitzAll #K35999R. Don't know if anybody else sells the end. But obviously, you can buy the hat seal most anywhere. They're about $3. Probably even cheaper, if you buy local, where you don't have to pay shipping. http://www.ebay.com/itm/TransTec-700...ZS6aM3&vxp=mtr https://www.summitracing.com/parts/ado-1259475 http://www.jegs.com/i/ACDelco/065/1259475/10002/-1 http://www.rockauto.com/en/parts/acd...ick+seal,10970 How about $.79 ? http://www.oreillyauto.com/site/c/se...zer&vi=1050714 Last edited by ponyakr; 01-16-2017 at 01:12 PM. |
I used a Lokar tube.
How well did it work?
Were you able to add fluid easily with it?
I liked it. Had no choice, the x-bodies that had Pontiac engines didn't come with a t400.
It came with a fitting that went in place of the dipstick to fill. I just left it in the glove box. Very good quality and no leaks. |
The reason I asked was because I'd always read that it takes an eternity to fill the trans due to the small ID of the Lokar tube.
Good chance that a first-gen F-body TH400 dipstick tube would have fit your X-body Ventura.
I don't know what body the tube came off of. I don't recall the exact problem other than it had interference. |
Since the fluid didn't leak out of the O-ring when the car was new, then something has changed. Most of the time it is simply an O-ring that is damaged by physical abuse or old age. Before ordering out some questionable space age solution, find a new 0-ring the correct size and lube it up with trans fluid before sliding it in. If you get the tube sideways sliding it in, it will slice and dice the new one. Don't think anyone mentioned that the excess fluid comes from the torque converter draining down. The converter holds a lot of oil, and it drains out over several days back into the pan. If a car is driven every day, only some of the oil comes out of the converter, but give it a week and the oil level will be down to the bottom of the converter output shaft and raise the level in the trans over the top of the hole in the trans body. Really helps to install the tube on a lift where you can view the tube going in the hole to keep it straight. What you think is a straight shot from above is usually anything but. I've only used a "top hat" seal on my 200-4R trans that had the same diameter hole in the trans, but has a smaller dipstick tube. I can't see any way that you could get both the 1" long grommet and the standard 400 tube in the hole.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
I use this one in almost every Pontiac build I do.
https://www.summitracing.com/parts/ati-406491 But it looks to be the same as the TCI unit. The Lokar one is a joke and a pain in the arse. Try the mod that the others have suggested. Any GM tube from the junkyard with have the same end on it, FWD or RWD on vehicles dating back to about 87. They used that same grommet to seal it into the case on just about all transmissions and transaxles
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT Last edited by ErikW; 01-16-2017 at 09:06 AM. |
