Fast ratio steering
Long story short, 66 Gto had for 20 years now, was looking into a 12:7 JGC deal, ran into a guy who said he helped the owner put in a Monte carlo SS gear box in my car...…..No idea if this is true or not...…….the # on the gear box is 7826692.
Jacked up the car today and I get about 3 1/4 turns lock to lock with a Grant 15" inch steering wheel. Checked with Power steering. com...……...says that the casting # doesn't tell you what you have for gears in it...……...says most have the 16:13:1...…….so I have no idea of whats what on this deal. Any ideas on this...……..hate to buy a different box, if this is what I already have. The steering seems ok on the car, just seems way to easy to turn the wheel, im talking 1 finger to turn the car while turning. Any help would be great here. Rich |
"Lock-to-lock" means NOTHING unless you also have the range-of-motion to compare to. I have a 2.5 turns lock-to-lock steering gear on my 'Camino, but the range of motion is so restricted I need forty acres to turn the thing around.
"Pinky-finger steering" is mostly a matter of the torsion bar diameter in the steering gear. A weaker, smaller-diameter torsion bar makes for easier, Grandma steering. I don't know of any application where they put a small torsion bar in a steering box with a fast-ratio gear set...but I don't know everything. The Jeep Grand Cherokee box has the second-stiffest torsion bar, and a nice fast ratio--AND it has the proper range-of-motion to retain proper tire angle. |
One thing you could look for is an ink stamped code on the end cap opposite the steering shaft.
A Monte Carlo SS box will have YA stamped on the end.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
I have a Monte Carlo SS steering box on my 64. Was much better than the factory box
Schurkey, I get what your saying...…..car seens to turn around fairly well, not like a new car but not all that bad either. Guess I gotta find someone who has the better steering on their car and see if I can drive it...……...just hate to spend the money for a JCG box and find out its the same as what I have now Rich. |
GM G body boxes like for the MC SS and GN do not have have the same internal stops as what is needed for our A bodies. You will have reduced turning radius.
Sent from my SM-T817V using Tapatalk |
Give a call to "Turn-One" in Saginaw, Michigan. They built my box and do a lot of NASCAR boxes and can tell you exactly what you may have and or modify your current box to enhance it to suit your needs. Mine is 2.5 turns lock to lock.
Tim john--- |
I run an Iroc box in several cars. It bolts right in, and is incredibly fast and pretty heavy feeling.
It's priced right too.
I have a custom Steering Box made for my 64 GTO.
The car turns well and has the stops in the right spot for a A-Body vehicle. It was built by Tom Lee, in California, years ago. Unfortunately Mr Lee is no longer in business (has retired). At the time, it was one of the best P/S boxes out there. No clue what P.S box he started out with. I have heard that a LOT of people like that Jeep Grand Cherokee box. Tom V.
https://leepowersteering.com/ |
Jeep Grand Cherokee steering box for me, big improvement over stock, bolts right in, and cost me a total of $25.00 including the Chevy truck coupler from the local Pick and Pull.
Fast Ratio
Folks, Lares Corporation in MN can rebuild your original box with updated internals.
1969 GTO Convertible 1969 Camaro Convertible, 350/3spd. 1969 Camaro Z28, NOM |
what year Cherokee did you use, and what did you put it in?
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
He built me a great steering box. If he still has my records I will post the mods he did for me. Tom V.
A topic of interest, valving and road feel. I bought a AGR box with 12:1 ratio and upgraded from the standard 210 valving to a firmer 220 valving. Absolutely outstanding out on the open road with the firmer valving. The upgraded valving provides a firm road feel, like what you might find in a modern sporty car like a BMW, etc, yet for my needs it's adequate for around town and related parking.
93-98 Cherokee steering box is required, Will need to adapt the metric fittings on the box if you have an older pump assembly, Borgenson makes the adapters part number 925122 this will allow the use of the stock lines, need a new rag joint as well Dorman 31011
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
Inexpensive with great information and perfect feedback;
https://www.ebay.com/itm/QUICK-RATIO...-/323091326790 |
Steering Boxes
I've heard some.good reports from this local outfit. The 4x4 circles also like this co.
https://redheadsteeringgears.com/# Also , theres someone on Facebook that is selling reworked Jeep steering boxes |
Strange that the seller says that "most" 70-76 cars used 12.7:1 . And that if you have those years you won't notice a difference in ratio. That's just not true. They were slower, variable ratio boxes. If his boxes are really 12.7:1, you'd notice a big difference in those years, and later years too, up to the early 80's. The 12.7 boxes didn't show up until 1984, and that's why the 85-87 Monte Carlo SS box is a sought-after box. The WS6 79-81 Trans Ams only had 14:1 boxes, which were the quickest up to those years. So, I have to wonder how accurate his information is.
Steve F. |
