A little damage...
Detonation makes for ugliness.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
Ouch!! Hopefully it can be repaired
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I see your blower is for sale.
Is this the end of this streamliner engine project or simply a revision ? Boy that head sure looks terminal.
Marcella has been known to repair some messed up heads.
But that one looks pretty bad. Sorry about your troubles Jack. |
Wow. Sorry Jack. Hope you can repair it.
Very sorry to see this.
Wow, look at the cracks even around the head bolts! That head was lifting off the block a crazy amount. That can likely be fixed, but at what cost, it would be monumental if you can’t do it yourself I would think. How does the crank and the rod bearings look? The bearings must be badly hammered? How long has this head been in use?
WOW!
Sorry to see that damage. Was this on alcohol? What's the plan now?
Wow, that's pretty bad Jack. Sorry to see this. I've been following your project for many years now. I see your blower is for sale, you putting this project to bed?
Better to have built a one of a kind awesome engine and blown it up than to have run a cookie cutter boring one.
Interesting to see the thickness of the casting. Sorry to see it blown up like that. If I still had spare heads I’d give you one to replace it but you know I sold them. I hope you still have some ideas for another project. Rob Maybe you could cut the head in half and built a two cylinder Hemi………..😎
" Darksiders Rule "
The Following 3 Users Say Thank You to misterp266 For This Useful Post: | ||
I have seen some worse than that repaired. It's a setback and opportunity for upgrade. The only positive statement I can make.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
That should buff out!
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Ouch, that's a big chunk gone.
Care to go into some details you think might've caused that? Someone said blower, what boost psi, fuel, AFR, timing etc? Curious what they would charge to repair vs buying a new head that you 100% can guarantee to beat on again and right away.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
Wow sorry to see this
Sorry to see this Jack. You are an innovator and I feel lucky to have been able to follow some of your exploits. I hope you are able to recover from this.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
3D scan cut a new one from billet?
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
Bingo! Looking at the breakage- how fragile that old casting was- I regret starting the project with it. A billet would be the way to go.
I've decided to build the engine as a 91 c.i. two-cylinder (#1 & #4) and drop down to H/BFL class. That will only require some crude TIG welding to close up the water jacket in #2.
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post: | ||
Well... that was just wishful thinking! Magnafluxing the Moldex custom billet crank shows a couple small cracks. So it needs to go back to Moldex for welding and straightening. Also found some cracks in the aluminum block's water jacket which need TIG welding.
Nitro?
No, methanol. I don't know for sure what caused the detonation. I originally had blamed myself for possibly not fully opening the fuel shutoff valve before the run, since the air/fuel log showed about 12:1 instead of the desired 5.x:1. But the other three cylinders don't show any signs of lean running and- only #2 had an oxygen sensor. Hmm... perhaps something was amiss with the #2 port nozzle or hose or J-block?
