Old 05-23-2024, 11:38 AM
napster's Avatar
napster napster is offline
Default 1970 T/A upgrades
I have had several upgrades done to my 1970 T/A. Before all the purists go bonkers on me, I saved all of the original parts. The car has 37,000 original miles with a NOM engine.
First, I had to have some body work done that I suspected was a problem when I bought the car. The original windshield was removed and it was not damaged along with the antenna. Both were reinstalled with no problems. You will see the area in question in the picture of the lower right corner of the cowl. It was fixed and the windshield was reinstalled with no problems.
Here is a list of the other items upgraded:
Upper and lower tubular control arms
QA1 coil overs up front (single adjustment)
QA1 Shocks in the rear – single adjusted
Bigger BMR front & rear sway bars
Changed front rotors with slotted & cross drilled rotors and new brake pads
Installed braided stainless steel brake lines
Changed intake manifold with a real deal RAIV intake. Reproduction wouldn’t up (way off) and caused vacuum leaks. Estimate 10 HP picked up from relieving bottleneck.
Valve train upgraded with Comp cam Evolution lifters – This removed the noise I had before.
New valve covers from Butler Performance
New March serpentine belt system
Griffin radiator and electric fans from Derale – Two 17’ fans that pull 4,800CFM
LED headlights
Previous upgrades:
Stroker kit for engine
T-56 transmission
Subframe connectors
ID:	634147   Click image for larger version
ID:	634148   Click image for larger version
ID:	634149   Click image for larger version
ID:	634150   Click image for larger version
napster's Avatar
More Pictures
ID:	634152   Click image for larger version
ID:	634153   Click image for larger version
Old 05-23-2024, 01:07 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Nice work.
Very nice work. Good upgrades for performance and stopping power.
Just one question. What is that Curley Q thing holding that heater hose?
Lol
Very nice over-all.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 05-23-2024, 01:19 PM
napster's Avatar
It replaces the ugly hose brace from the factory.
Old 05-23-2024, 08:24 PM
Formulabruce's Avatar
Did you turn the heads into " cathedral " intakes as the RA 4 has when you put on the intake? Or you running ra 4 heads?
Old 05-24-2024, 01:04 PM
napster's Avatar
Take a look at post#2 second picture. You will see a 614 head.
Old 05-24-2024, 01:41 PM
skunkwerks's Avatar
Default upper dash
What product did you use to repaint your upper dash or did you not?
Just wondering cause there is an on-going debate on what product looks like
the original matte finish.
You taken the car to the strip? Any time slips?
Old 05-26-2024, 01:28 AM
I like the balanced look of the March set up on left and right .
Engine should be fun to drive
Good brakes and good headlights shouldn't hurt.
My 70 is going to get the 614 upgrade , and probably a non-stock color change with stripe delete.
Maybe a 4+1 Nash and 3.07 gears
You aren't hurting my feelings .
Old 05-28-2024, 12:55 PM
napster's Avatar
Baron,
Thanks for the comment. The car was a hoot to drive before the upgrades. I'll post something once I get the car back. The engine was estimated to put out 460 HP before the upgrades, but the is expected extra power of 10 to 15 HP from the better intake and electric fans.
Old 05-29-2024, 09:26 PM
A friend had a 4+1 in his 70 Formula. Good trans, but the noisiest manual trans I ever heard. It made a rock crusher seem quiet.
Maybe a 4+1 Nash
Old 05-28-2024, 12:50 PM
napster's Avatar
You are not going to like what I tell you about the dash paint, but here it goes.
The first paint tried was the Ditzler paint from their chart posted by John T/A. The paint didn't match, so 3 other paints were sampled out and they turned out to be off and shiny. Here is where the Boo Hiss starts, a lot of time was spent on this single issue and Lucerne Blue was put on and applied flat. To myself and people at the shop we are in agreement it works. I know this will P.O. some people, but I'm fine with it and spending crazy money on it was not going to happen. The picture of the final product is in the first post, picture #5.
With regard to the track and time slips, I don't race.
Old 05-29-2024, 01:54 PM
skunkwerks's Avatar
Thanks for the update. Where did you get the Ditzler mixed up?
Local or from TCP global. Has to be the correct lacquer with shellack Beattle additive for the correct dull look. Just wondering what you used as it looks fine to me in the picture.
Old 05-27-2024, 12:44 PM
R 70 Judge's Avatar
Cool upgrades! How did you manage to get two 17” fans crammed in there? I have the Derale 16826 fan/shroud kit on my TA (which work great) and they are only 12” fans. Any pictures?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 05-28-2024, 01:09 PM
napster's Avatar
R 70 Judge,
Thanks. My mechanic installed a Griffin radiator for a GTO in the '70 T/A along with the fans. Modifications were necessary for both items and I will provide pictures and a video for your consumption. These upgrades were necessary in my eyes since I will be moving to Florida and I want to give this car the best chance it can have to survive the heat.
The Following User Says Thank You to napster For This Useful Post:
Old 07-10-2024, 03:58 PM
napster's Avatar
R 70 Judge,
I still haven't got the car back. However, I was at the shop and took some quick pictures for you. I plan on doing two videos once I get the car back. One will be of the under hood and the other will be of the underside. I know the videos will burn up some purists on this board. Nothing I can do about that, but it's my car and the resto mod changes are what I like.
I will also follow up with a video of the changes to my '73 T/A once I get that back.
ID:	636606   Click image for larger version
ID:	636607   Click image for larger version
Old 06-03-2024, 08:50 AM
napster's Avatar
R 70 Judge,
Here is the fan setup on the car-
https://www.summitracing.com/parts/d...QaAihNEALw_wcB
Also, the alternator is a 130 amp example which was part of the March system.
Further, had to change the carb. The one on the car and was used for the dyno in 2016 turns out to be a Holley 780cfm vacuum secondary carb. My mechanic could not tune it the way he wanted since the car was running way too rich. Looks like the new carb will be a Quick Fuel 750 cfm double pumper. Might get a few more ponies out of it.
