On the bottom of the dual snorkel air cleaner there is a large hose and fitting. Where does that hose go and who sells that fitting?
It goes to the DS exhaust manifold shield. It's a flexible tube. The steel shield is retained by two of the head bolts that have studs on top.
Greg Reid Palmetto, Georgia |
where can i get the elbow fitting?
As far as I know it's just a foil covered paper like tube that attached to the elbow you see on the air cleaner on one end and the manifold on the other. They're just held on with band clamps. Ames should have all of it.
this fitting
I'm pretty sure someone added that.
It should look like this:
![]() Those look to be two different air cleaners. The degreee of separation between the snorkels looks different as well as where the vacuum tube from the thermo heater dashpots are. Is one a 69-70 annd the other a 71 on up?
1968 Pontiac GTO - Verdoro over Ivy Gold - 400/4-speed/3.08 1987 Pontiac Grand Prix - Sage/Sage/Sage - GM 305/Th200-4r 2004 Pontiac GTO - IBM over Black - LSx 440/6-speed/4.10 SRA - Single Digit Stick Shift |
Sorry, I totally misunderstood that you were talking about the rubber hose.
Must have been a Chevy owner...
As mentioned by UJ above, not Pontiac factory. It's how BB Chevys attach the breather tube.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
The Following User Says Thank You to OG68 For This Useful Post: | ||
![]() Quote:
OP's photo with the hose and 90-degree elbow looks like the bottom side of the air cleaner vs your photos of the top sides (filter side) ???? Mike |
![]() Quote:
The circled items are temperature controlled vacuum valves. When cold, they allow vacuum to pass through to the servo that allows either cold air to come in through the snorkel or warm air from the flex duct that is attached to the shield over the DS exhaust manifold, and forces the warm air path to be taken. When they get to around 100F they stop passing vacuum to the servo and you switch to the cold air. The breather tube on the passenger valve cover connects to the foam filter that is on the passenger side of the air cleaner housing. In this picture, the top cleaner still has it in place. If you look closely at the bottom housing, the filter is missing but the opening is in the same spot.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Thank you!
69 is the wide separation and the other is 70-72.
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
the angle difference is an illusion;
those are two different 1970 model year dual snorkel air cleaners; the rear one is a 'dropped base' air cleaner for the Firebird, while the front one is a GP/GTO ect air cleaner.
oops, you are right, I didn't check the pic carefully enough?
The first picture is borrowed from the web. These are of my own air cleaner. There are too small holes for the vacuum hose connections. There is a 5/8" hole that I wonder about. I'm convinced it is factory because of the stamped area around it.
![]() Quote:
That isn't factory. Someone must have had heavy blow-by and plumbed it into the driver valve cover or crankcase to eat off more of the smoke. (guessing) trivial factoid |
For the carburetor fuel bowl vent. 70 (California) and 71 cars
The Following 2 Users Say Thank You to OG68 For This Useful Post: | ||
So this is a 70/71 air cleaner? Not that it matters. It's going on a 68
Like this?
