468 as cast High Ports
KRE posted on FB. 468 based on an MR1 block, solid roller, as cast high ports, 631hp, 5900 / 629tqe, 4400, 4.21 x 4.21, pump gas
Following instructions from KRE I made 618 hp at 6200 with KRE “310” d-ports on a stock block 474 with a solid roller spec’d by Jeff K with a port matched Victor , 850 mighty demon and 2” maddog headers on 92 pump gas 12 or 13 years ago...
Is the solid roller streetable? |
Regarding the 631 hp 468 combination did KRE divulge the specifications on that solid roller ? Or typical secret squirrel material !
Secret squirrel for now. |
Bwahahahaha.... it usually is !
Daily driver? I wouldn’t.
50 mile round trip cruise, just fine. Drove it for pleasure all the time. Could be tough on valve springs, comp 917, if I recall. |
What was the CR?
Stan
It would not take any sort of special cam to get 631 HP with High Ports. If you did not at least get close to that with a decent solid roller you did something wrong.
No many high power pump gas hp headed engines out there on stock blocks. But maybe you know of some?
631 HP pump gas is not exactly "high power" as far as I am concerned. 600 HP steet'able stock block engines have been around for a long time.
This engine is just a little more powerful. Not sure what the big deal is. You would have to try, not to make 600 HP. You can not tell me if I just bolted my High Ports on my old 455 I would not make 600 HP just the way it sits. |
A few combinations ago Steve C designed an excellent true street stock block 455 with Edelbrock heads that made right around 600 HP. He also was kind enough to share the results from a bunch of different manifolds he tested. It is easy to yap on the Internet about making 600 hp. and a lot more difficult to actually complete the project and achieve the number.
Funny I came across a post today from 2008 with some guy yapping about Hi-ports that have yet to see a splash of combustible mixture.... Again a lot easier said than done. |
One thing, I am persistent and have a tenacity about racing. Just like you will always be a pile. Whatever makes you feel better. This engine is going to rock. |
A man with your qualifications should be able to find a job sweeping the floor anywhere. Not sure about "tenacity" you've been trying to build this engine on here for two decades. |
You straight up lie about other porters, and get away with it. You have to lie about them to try and get whatever cred you think you deserve in your head, sad. You are nothing without spray. Its your go to move. No one in their right mind thinks it is difficult in any way to get 600HP with as cast High Ports. So I say as much, you don't like it, don't care. 'tenacity" was about actually racing. You know, the pic with all the trophies on the single 455 engine, that one. |
why such a small bore on an MR1 block? Maybe KRE just wanted to show what could be done with a factory block and as-cast high ports but it was easier for them just to build an MR1 than do all the prep work to have a factory block live at those power levels?
The Following User Says Thank You to i82much For This Useful Post: | ||
I believe it was a swap over from a stock block. I posted this simply because it made over 600hp on pump gas with untouched heads. |
Gotcha. Would be neat to see them run the same engine with different bore/stroke combos and see if it gains any power as a 505 or 535. Of course, it is very easy to go on the internet and spend someone else's time and money!
LOL! It's an interesting build and shows what can be done with a pair of "off the shelf" cylinder heads. |
Closed Thread |
