rod bearings
anyone know who makes a pontiac rod journal size, doweled rod bearing? trying to find some for use with bme rods but im not having much luck
http://performerrpm.myphotoalbum.com/view_album.php? |
Buy any rod bearing you like and have the holes drilled.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
and i actually thought about that already...just for some unknown reason i guess i felt like i shouldnt do that😁
The Following User Says Thank You to performerrpm For This Useful Post: | ||
Speed Pro 7050 CHA They are very hard to find since the advent of the aftermarket cranks that almost all have the 2.200 journal. The A designation means aluminum rod with the locating hole. I made a drilling fixture out of an old rod cap and drill them in the mill. Put a nice chamfer on the inside.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Be sure to have the proper size numbered drill bit and a spare before you dive in all the way!
Start off with a good amount smaller starter bit going thru all the way, and then use the needed size final bit and go thru from both sides of the bearing. Do 2 practice runs on a old bearing if you have such, even if it’s a main bearing,
Back when I ran aluminum rods I made a drilling fixture from an old stock rod cap. Drilled through the cap at dead center. Helped to hold it securely in the drill press
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
So aluminum rods have a locator pin for the bearing to prevent spinning bearings? Why wouldnt this be used on steel rods too?
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
Aluminum rods , even those hardend to T6 spects are so soft as compared to steel or cast iron / Armasteel that they can not develop the needed amount of bearing crush at the big and small end of the rods parting line to hold the bearing from spinning, plus Aluminums expansion rate is much higher then other rod materials when heated.
It’s the crush / compression of the bearing at the parting line that keeps any bearing be it main or rod from spinning, bearing tangs only serve to locate the bearing left and right in its bore.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 01-24-2021 at 01:32 PM. |
This is how I did my BME bearings
If your not at the table you're on the menu A man who falls for everything stands for nothing. Last edited by Formulas; 12-17-2023 at 10:11 AM. |
I did the same as the other guys when I ran aluminum rods used an old rod cap.
thanks. my brothers a machinist so i think ill have him make me up a old rod cap as a template like was mentioned....otherwise ill have holes all my bearings an none in the right place
Order 1 dowel hole bearing, use as drill hole template in rod cap .
post # 4/6/9/10 : same way I did it before I got Mickey Thompson's bearing drilling fixture.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
do u have a part no for a bearing? the one mentioned uo top is pretty much non existent bear as i can tell so if theres another out there you know of?
What size is your crank pin ?? I might have a set of .010 under Pontiac size rod bearings that were drilled torqued in but never ran
Also your going to want to verify dowel size to make sure no surprise changes there Pulled them out of the deep freeze pole barn ACL brand about .181 dowel
my crank is a new forged crank so its still standard pontiac rod size. yea the dowel is not real big in tge rod cap, almost look like some kinda grease zerk at first to me since i hadnt ever seen a rod with them before
