LS Guys.......
Saw this in OC yesterday, guy did a really nice LS swap that would fool a lot of people. Not my thing obviously, but it was VERY well done.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
The Following 2 Users Say Thank You to OCMDGTO For This Useful Post: | ||
Very clean!
Looks great.
Well presented, not a fan of the creature head on the air cleaner but the engine looks right at home.
Tim john--- |
Here is a 1973 VW Squareback that belongs to my friend. It’s equipped with a ‘99 LS1 and 4L60E from a Corvette and has a tube chassis with a Mustang II front suspension and a 3.70 geared Ford 9” with ladder bars. The air conditioning works pretty well and it gets around 21 mpg.
The car weighs in right around 2500 pounds and with traction it should run mid-11s, the engine is stock.
The Following User Says Thank You to b-man For This Useful Post: | ||
I'm gonna have to see if I can track this car down, tomorrow or Saturday. My 400 is on it's last legs (almost no oil pressure), and I'm looking at all options.
'67 Piper Cherokee '66 Lemans |
OCMDGTO: did you note if that was carb or throttle body injection?
Well this should give you LS guys something to shoot for. A Pontiac I feel has to have Ram Air. This hits the mark....
The Following 2 Users Say Thank You to 65madgoat For This Useful Post: | ||
like this?
Does anyone know if the serpentine setups in posts 1 and 9 are stock or aftermarket?
67 LeMans, 326, M20, 3.31 12 Bolt |
Scare, I'm pretty sure it was EFI
Here's another I saw in a TA
To be able to use a stock air cleaner would be beneficial; ie Shaker hoods, Ram AIr, Cowl Induction etc. for LS/LT swaps.
I wonder if they ran a speed density tune as there is no prosion for a MAF sensor? |
Do they make an adapter for the Pontiac covers, or are people just drilling and tapping sbc swap brackets?
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
73 LS9 TA
Here’s where I am at this point - after re-routing AC and Coolant lines up and under passenger fender and IC pump / front light harness up and under driver’s fender. Looking for clean coil covers now…
Very clean. Nice job!
The Following User Says Thank You to JSchmitz For This Useful Post: | ||
https://www.summitracing.com/parts/hly-241-191 https://www.holley.com/products/ls_p.../parts/241-190 |
I have ICT brackets on my engine. The alternator charging stud is very close to the factory valve covers. I cut it down a little. Might be a problem with the Holley coil covers.
Nice. And still multiport injection I believe.
