63 wagon ratios
I stumbled across a mostly complete 63 Catalina wagon in a junkyard. It looks like
a 389 auto car. What are the chances of it having better than a 2.56 ratio? And how hard is it to use that rear in a '66 Catalina? I'm stuck for my car and the wagon rear is $200 |
Looking at my '63 Service Manual..
a Series 23 car (SWs not separated) it could only have a 2.56 if it did NOT have AC... If it has AC then it would have at least a 2.69 gear. But.. either way.. Im betting its under 3... either 2.69 or 2.87. Its still better then the 2.41 open that my 66 Ventura came with. Cant talk about reuse.. never thought about trying it so never directly compared them . IIIRC though I think its problematic to do.. though I cannot recall why. John
Not all who wander are lost... 1964 Starchief 4 Dr Sedan - 389 4Bbl - Auto - Pinehurst Green/ Gold cloth 1964 Grand Prix - 389 4 BBl w SupHyd auto 1964 Catalina Safari - 63 389 200r4 auto.. 2.69 POSI rear 1964 Bonneville Vert - 389 4bbl - Auto - Ext Color - Saddle/Saddle int 1965 2+2 - WG 421 4Bbl - 4 spd - Bluemist Slate w White/black int 1966 Ventura 4 dr Sdn - 389 4Bbl - Auto -Orig Color - Barrier Blue |
I figured as much. I think gears are available for the 63 rear I know they aren't
for the '66. I'll have to check when I have the money so he doesn't go up if it's a good gear. |
the more people that call to Brad at Fabcraft and request gears for the 65 + rear, the better chance that he will make another run of the 3.55 sets.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
a better place to go then with the 2.93s i can put it in now.. I think it would be a world of diff..but... will have to deal.. John
It is easy to tell what the rear is by looking at the case if you can get to it. "what they came with" is pure guesswork. You never know what you will find. Not going to interchange w post '64.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
I've talked to him as well. He said another run of 3.55 probably won't happen.
He's the one that suggested I try to use the older rear. |
I have a 3.42 posi for your car 65-70 fullsize $500
Have you considered a Curries 9"?
There is a board member here who did that in a '66 Catalina. Where's the '63 Safari, do you have any pics of it?
" Darksiders Rule "
I appreciate the offer for the 3.42 but my budget is screaming with a baby due
in 8 days. The safari is in a local junkyard. It's probably been there 30+ years but seems solid. Someone took the timing cover off but everything else seems to be there. The 9 in inch is the same as the 3.42. I have a cut off wheel, grinder, and welder so figured I could move mounts and brackets around. |
You could use 65 up to a 70 big Pontiac rear, and be able to make use of those tools and skills to make one fit. Earlier would be too much BS. Wagons would be a slightly better bet for ratios. A 3.08 is great and not too hard or expensive to find. Much more affordable than the 9" or Fabcraft option.
I ran 3.08s in my '71 Catalina and liked them. I did crutch
them for a while with a Saginaw 4 speed with the 3.50 ish first gear. It soon exploded though with attempts at power shifting and 4500 rpm clutch dumps (I was 18 and dumb) |
Drum to Drum
I'll keep that in mind and if I can make any extra money
at part time job #2 and #3 this summer I'll probably try to get it. I figure I'll have to add another $200 plus for fuel to come get it. |
I'll meet you halfway.
