Is there an original dealer selling price list out there somewhere for all the 61 Pontiac models?
What year 5 lug brake drums interchange....59-64? Also.....just checked on Rockauto...and no rear shocks are available. Any other sources? Thanks |
5 lug drums are the same 59-64, for some reason RA doesn't show them for a 62 but 64 also used the big 9.3 rear and it has them listed for them. (raybestos 2265R) They don't look exactly the same (new replacements are finned vs OE smooth) but they fit fine.
Same with shocks - though I'm not sure if the upper mount is the same between 62 and 64, so you'd need to confirm. I have some KYB gas-adjust shocks in there now but not sure if they won't be changed out by the time its on the road.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
![]() Quote:
Drums are currently out of stock.... The rear shock listings ...are hit and miss 59-64 should be the same I think... I found a cheapie Monroe rear....that should work.....I will advise when I attempt installation.. |
![]() Quote:
I sourced the lower stud kit...and am tempted...to try them...even though they are short...... THoughts? |
I asked the same question about rear shocks back in December, here's that discussion: https://forums.maxperformanceinc.com...d.php?t=855458 Apparently the deal is the lower mounting stud is included with 1961 shocks but isn't included with 1962 shocks, so you have to press the stud out of your old shock and reuse it with the new one.
I have copy of John Gunnell's book '75 Years of Pontiac-Oakland' that was published in 1982 by Crestline. It has a limited amount of pricing info including base prices for some models as well as prices for a few options (for instance, base price for a Bonneville two door hardtop was $3,255, and 8 lug wheels were a $107.06 option.) If there's a specific model or option you're interested in, let me know and I'll check to see if it's included in the book. |
The picture from the 61 manual in Stuart's post doesn't look like what I have on my 61 as to the lower mount. Probably the lower has already had the parts store replacement lower stud installed and had the "62" shocks installed. I didn't buy and install these shocks so I can't say for sure. But it would appear that with the replacement lower stud that 62 shocks should work. That tape is only in the picture from when I was considering adding a sway bar and wanted information.
![]() Quote:
I moved about 5 years ago......and the library is still a shambles........lots to unpack ... I guess I'm "internet lazy".......but still love my car books/magazines.. I'd be happy knowing what the MSRP was on all four 61 Bonneville models. |
From '75 Years of Pontiac-Oakland' by John Gunnell, 1982 Crestline Publishing:
1961 Bonneville station wagon $3,530 1961 Bonneville convertible $3,476 1961 Bonneville two door hardtop $3,255 1961 Bonneville four door hardtop $3,331 Some options: Outside rear view mirror $5.54 8.00-14 whitewall tires $40.78 8.50-14 whitewall tires $62.00 Backup lamps $14.31 Bucket seats $116.21 Eight lug wheels $107.06 Dual exhaust $30.88 Tinted glass $43.00 Air conditioning $430 Hydramatic transmission (the Roto-Hydramatic in Catalina and Ventura) $231.00 Power brakes $43.00 Custom wheel covers $31.00 Two tone paint $12.80 Power steering $107.50 Guidematic headlight control $43.00 Circle-Aire heating $94.135 Direct-Aire heating $75.32 Safe-T-Track differential $42.50 Windshield washer $13.02 Electric antenna $30.88 Ash tray lamps $4.25 Underhood utility light $7.10 Power seat $96.84 Electric tailgate window station wagons $31.85 Station wagon roof luggage rack $98.56 |
Awesome...
Thanks for taking the time to post... |
You can buy universal shock mounting stud packages new that work just fine. I used them on my 1962.
Just wondering what the purpose/significance is....of this upper bumper bolt?
On my car it appears to be cosmetic....there doesn't seem to be a bracket behind it... |
I've always wondered the same thing. There's no mounting bracket there, or provisions for some sort of optional guard or anything. I believe originally there was a snap in plug that went there, rather than an actual bolt.
![]() Quote:
'nother question for you..... I want to install this gas door guard....and when I removed it from the parts car....it had 2 bumper bushings...with screw holes in it.. I need new ones and the replacement ones I see are just push-ins... Any clues on where I can find correct ones? Am going to invade the local True Value fastener isle....next week.. |
Don't know of anywhere that has those specific rubbers but you could check Steele Rubber or Metro Molded Parts to see if they have anything universal that's close enough. Another potential source is https://www.clipsandfasteners.com
Those pseudo bolts were used a number of times for years. The 61 has one on each side on the front as well. If I remember correctly Chev 49-52 had one at the center of the bumper. They got an unthreaded bolt that was held in with a spring clip "nut".
" Darksiders Rule "
![]() Quote:
![]() Quote:
Ok...I've ordered the Brand X bumpers......
I will change out the torx screws...for some pan head phillips...and nobody will be the wiser.. Does anybody know the bulb #'s....for the dome/map reading lamp? Thought they might be in the owners manual...but didn't see them there |
![]() Quote:
This is a good tool, or in rock auto "electrical - bulb & socket" https://www.rockauto.com/en/catalog/...-bulb+&+socket
