porting went wrong
i have 2 holes where someone went into the water jacket on 1 96 d-port head. its small i think...can i use devcon to fix this? if so which devcon product? i have researched this and my head is spinning.no pun intended. my plan is to patch this so i can run for the summer meanwhile send some virgin 96 d-ports to butler for a port job. what do the experts here think? this was found out after the heads had been cleaned by my local machinist. I just put a new cam and rockers in and was hoping to be at the track and this was found out last friday,
72 Luxury Lemans nicely optioned |
And i cant load pics....
Grab another 96 head, can’t be that expensive
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
The Following User Says Thank You to J.C.you For This Useful Post: | ||
I know some new head are found so it is not really an issue fixing these anymore. But, I frequently weld iron heads and use epoxy on heads. Looking at those pictures of the problem area you could definitely have added epoxy and ran it. Bolzona or Resibond are probably the best IMHO. Followed by Splash Zone, then Moroso A-B. JBweld is ok for some stuff. Splash zone was out of stock last time tried to ordered it. If you want to never have an issue with epoxy use to Evans waterless coolant.
There is plenty of room for epoxy there on that spot in the bowl. I would actually epoxy all the ports in that area, (Steve25 said it also on a earlier post). Most times I ported and intake like that I lost flow. There is no reason to cut the bowl down that deep. If the port gets extremely thin I will weld and use epoxy. This Resibond is what I use on the exhaust side. Last edited by Jay S; 05-07-2024 at 04:28 PM. |
Also, I don’t think it was mentioned, but if you are using Ethanol, it can lift Splash Zone, Moroso a&b, or JBweld. For E15, and even E10, they need covered with a urethane paint to protect them. Belzona 1111 is more resistant to ethanol and antifreeze than those, and doesn’t require anything special to protect it. It is more expensive though.
The Following User Says Thank You to Jay S For This Useful Post: | ||
yea i just found a set but they are going to butler and i dont want to be without my car that long. these had some type of epoxy but it didnt last under the cleaning process. plus i was running these heads for 10yrs with no issues.
If you're looking to use epoxy to fix the holes, Splash Zone marine epoxy holds up very well. I also have a set of D-ports that have Moroso AB epoxy, and has been ran for 10+ years with no problems
The Following 3 Users Say Thank You to Scott Stoneburg For This Useful Post: | ||
both of those came up in my searches as well. Thank you.
Resbond 907GF is what I use for exhaust work. heat rating…2350*F
Why can't you load pictures, do you need guidance?
I would like to see pictures of where you went through. 1) if you ground thru near the head bolt boss repairs do not hold up for long due to the loading of the cast iron there. 2) depending on where you ground through you may have deminished the stock flow levels if you did such without the guidance of a flow bench. To grind through even on a head with core shift you have had to grind through some .050" of wall thickness which then means that to have the correct port shape the whole port would have to be majorly reworked! PM contact me if you need guidance to post pictures.
Pics so I could figure it out lol huge thanks to steve25 for the text message guidance you gave me earlier today! I really appreciated the tips! Thanks again. Butler is 6 months out to port the new heads I got and with your tips on fixing these I should have it on the road in two weeks!
I forgot to mention that if the other 6 intake ports are scalloped out like those 2 then fill them in as well.
When done it should look like your other set of 96 heads.
epoxy isn't going to hold long into a water jacket.
it needs to be professionally welded. that has to be at least brazed, gas welded with a torch. or professionally cast iron welded which is more cost than the heads are worth. |
I did the same thing when porting the heads on my 403 Olds. I had a friend who is also a very talented welder braze the hole up with bronze rod iirc. I ran that engine hard at the track for many years and never had a problem.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
The Following User Says Thank You to prostreet64 For This Useful Post: | ||
yeh the NHRA SuperStock class engine builders have been filling exhausts ports with braze for decades. it works.
The Following User Says Thank You to GTO-relic For This Useful Post: | ||
I've used JB-Weld on cast iron heads before to with good success.
GT |
The Following User Says Thank You to blueghoast For This Useful Post: | ||
It's the antifreeze that eats epoxy
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
The Following 2 Users Say Thank You to joes455 For This Useful Post: | ||
epoxy should never be used against a water jacket or in an exhaust port, period.
it won't hold up. only for pushrod guide holes, head bolt holes, or breakthroughs into crankcase pressure area. it'll seal vacuum, atmospheric pressure. that's about it. a simple head bolt hole break, you could seal it with even permatex if you wanted to. |
Dave Polichena |
He only needs to get thru the summer on the repair work, not for years
